roach374
roach374
I did a front-end swap on my '93 K75, and I'm now trying to cut a custom clutch cable. What's the best way to ensure the correct length of the cable and sleeve?
What I came up with (interested in feedback): The bike has a connecting rod between the clutch lifter arm and the kickstand (so that when you pull the clutch, the kickstand goes up). I figured I should cut the cable to length so that when the kickstand is down, and the clutch is not pulled, the lifter is right up against that connecting rod (so that even the slightest pull on the clutch will raise the kickstand). Is this the right approach? Should I add more play in the cable?
1993 K75 standard
The procedure for adjusting the clutch specifies 75mm of inner cable free length. Adjust your lengths to get that dimension with the adjuster at the lever screwed out 5-6 turns from lightly bottomed.
Suzi Q
Suzi Q
The link rod for the sidestand retractor has its own adjustment - the rod is threaded. No need to worry about it, just set the cable per .75's post, and then snug up the link rod as you've described.
...or you can take it off and throw it away, it wasn't BMW's finest design triumph imho.
roach374
roach374
Point-Seven-five wrote:The procedure for adjusting the clutch specifies 75mm of inner cable free length.  Adjust your lengths to get that dimension with the adjuster at the lever screwed out 5-6 turns from lightly bottomed.
Brilliant, thanks!
1993 K75 standard
