1Back to top Go down   Greetings, and those in abundance Empty Greetings, and those in abundance Fri Mar 26, 2021 8:06 am
shugie
shugie
Picked up a "project" 1992 100RS 16V which looks to my untutored eye to be in tidy nick for the year, had two boxers and three BMW singles, this is a first K for me, and possibly going to become an outfit at some point, always fancied the weird and wonderful world of three wheels.
Welcome! I think you're going to really like that bike. I'm on my second, and for riding around town or day trips is the best bike I've ever owned.
3Back to top Go down   Greetings, and those in abundance Empty Re: Greetings, and those in abundance Fri Mar 26, 2021 10:49 am
shugie
shugie
Point-Seven-five wrote:Welcome!  I think you're going to really like that bike.  I'm on my second, and for riding around town or day trips is the best bike I've ever owned.
Compared to the later BMs it's very solidly built, and quite heavy, the 650 XCountry I had last weighed about 100kgs less, but was not good on the motorway.
4Back to top Go down   Greetings, and those in abundance Empty Re: Greetings, and those in abundance Fri Mar 26, 2021 12:51 pm
Welcome Shugie Smile
Greetings, and those in abundance Eu-log10  K1100RS/LT - R1200RT - R1100RS - Cagiva SST 350 Ala Verde - K75LT project - K75 Schurgers - K75S - K1100RS - K75RT - K75C
td5
td5
Hey Shugie,
Tons of info here just ask, a K is a solid machine, basic maintenance and she'll go forever.
Greetings, and those in abundance K_engi10
1988 / K100RS
2013 / R1200GS
2015 / K1300R
2002 / R1100S BCR
Bonzo
Bonzo
Welkome Shugie,
Was your bike the black one I spotted over on the ukgser forum a few weeks back?
If so, it is indeed tidy  Greetings, and those in abundance 112350
1990 K100RS 4V (VIN# 6406682)
2017 R1200RS SE Sport
7Back to top Go down   Greetings, and those in abundance Empty Re: Greetings, and those in abundance Sat Mar 27, 2021 10:47 am
shugie
shugie
Bonzo wrote:Welkome Shugie,
Yes, less corrosion on it than either of my GSs, both of which were considerably younger. Going to need some new tyres front is 15 years old and still with enough tread to be legal.
8Back to top Go down   Greetings, and those in abundance Empty Re: Greetings, and those in abundance Sat Mar 27, 2021 10:58 am
Welcome along Shugie,
Sounds typical of the bikes that you can pick up...sit for a long time until the garage space is needed for something less interesting. You will find she handles a whole lot better on a fresh set of rubber. Depends if you’re going to ride first and then convert to a sidecar rig or go for the conversion straight away.
They are pretty good for corrosion resistance. However, the rear hoop of the frame does tend to be the area where corrosion can set in quite badly. It’s mostly hidden from sight (and therefore mind) by the ducktail plastic but, of course is in an area where lots of road muck, salt and water can get thrown up and then it sits there quietly rusting away. I haven’t heard of the frame failing through corrosion, but it is definitely an area to think about cleaning up and repainting if the back end of the bike plastics are off for any other reason.
Greetings, and those in abundance Uk-log10 Greetings, and those in abundance Sco-lo15
                              Paul  Greetings, and those in abundance 905546712
shugie
shugie
Thanks for that, you are quite right, that is corroded and concealed, will need to sort that sooner rather than later. Not decided on when the conversion will occur as yet, so probably going to ride as a solo first.
