1 Fuel leak issue Sun Nov 28, 2010 1:27 am
Cablebeacher
Hi all
I didn't quite know whether to place this in the electrical or engine forum. This will probably do...
There are a couple of fuel/non-starting/rought running issues lately. So whilst having read them and the possible solutions (and being aware of the Great CrazyFrog's Guide to EFI on this website) I have an issue that someone may be able to offer a simple solution to. This may save me going down the long road of checking everything in the EFI system...
1. K100 has been running perfectly. No problems what-so-ever.
2. It has been REALLY hot here recently so I wimped out and used the car to go to work. Bike wasn't used for nearly two weeks.
3. Battery was just flat enough not to start the bike so I purt it on charge.
3. When I went to start it yesterday afternoon I got a very good start with charged batty but would not fire. Then smelt fuel. Thought I may have flooded bike as Fast Idle was at first stop position as this is where I normally start bike.
4. Fuel was dripping from where header pipes bolt to the exhaust. The flow was not excesive but was a continuous dripping.
5. Waited 30 minutes. Fuel drip had stopped. Bike would not start and fuel drip had started again.
6. Removed tank. plugs and injectors over nigh. I am now going to check all the wiring under tank and re-assemble and see what happens.
So my questions before re-assembling are:
1. How was it the fuel was leaking at the header/exhaust area and not anywhere else?
2. Has something simply 'stuck' open and is allowing the fuel to be flowing in the system and then leaking out as above?
Regards
Mal
Regards
Mal
