1 Hello All! Thu Apr 08, 2021 11:29 pm
patto1ca
That's the goal, anyway! I'm in the process of finalizing a major refresh on my '95 K1100 RS with 99k miles. I've been reading this forum on and off for years, so thanks for all of the great insight and help. Once I'm finished, I'll put together a video of the whole process. I just need to wrap up replacing the timing chain, gears and finish the valve clearance adjustments. Waiting on some buckets. The bike was/is running great, but it was leaking from the usual places.
New: (not a complete list)
-Final drive bearings, seals, new shim proper clearance
-Shaft u-joints, new spline lube both, ends
-Powder coated rims (BMW silver)
-New clutch, plate, spring, etc.
-New main seal
-New wheel bearings
-New headstock bearings
-New rotors, fore and aft
-New braided steel brake lines
-Rebuilt masters, fore and aft
-Fixed and repacked the breather in the airbox. Now serviceable from upper removeable "cap."
-New trans seals
-New intake o-rings
-Cleaned, flow-matched injectors
-Rebuilt water/oil pump, all new seals
-New fuel pump/filter, hoses
-Cleaned all of the main harness connectors
-New progressive fork springs, seals
-New grips
-Cleaned (euro) ignition switch, start switch and every other connection/relay/connector
-LED headlight
-Replaced all lamps in instrument cluster, cleaned connections, speedo cal
-New exhaust o-rings
-New O2 sensor
-New water manifold o-ring
-New throttle, idle and clutch cables
-Bunch of other stuff...
-New main seal
-New wheel bearings
-New trans seals
-New intake o-rings
-New grips
-LED headlight
-New O2 sensor
