1 Bmw k75s no spark. HELP! Wed Jul 19, 2017 6:53 pm
jaimers
[size=33]Hi everyone, may be you could read on my introduction as new member that I am the owner of a non runner k75s which I'm planning to bring back to it's full glory.[/size]
[size=33]Work done so far has been continuity check of all wiring, cleaning of all grounds, all terminals cleaned/inspected for corrosion.[/size]
[size=33]Findings so far have been:[/size]
[size=33]1-Both wires connecting the fan were hard wired to the battery.[/size]
[size=33]2- 5 pin connector from halo sensors to ICU corroded, fair amount of white powder when I first disconected it.[/size]
[size=33]3- Fuel ignition relay had an added ground in order to make it work. [/size]
[size=33]Tests so far:[/size]
[size=33]1-halo sensors plug cleaned and both sensors tested using a 12v LED at the computer plug. One works one doesn't.[/size]
[size=33]2- I disconnected the ground someone added to the fuel ignition relay and the relay stopped working, I had no fuel pump anymore. The ground was added to the yellow/brown wire coming from the ICU which I presume is a ground so the ICU to power on the fuel system. [/size]
[size=33]3- I checked the coils, but I have no idea of the resistance value I should get. Both three are similar: 9.75k 9.9k and 10.05 k.[/size]
[size=33]Any thoughts of what I've done so far?[/size]
[size=33]Cheers,[/size]
[size=33]Jaime[/size]
