1 No power to fuel pump Mon Apr 19, 2021 10:17 pm
laxer
Hello, I'm getting all of my family's bikes ready for riding this summer, but my dad's 85 k100rs is being difficult as I can't get the fuel pump going.
Started out by trying to crank it but the battery was dead, turns out the trickle charger doesn't work anymore. Went to jump the battery witha spare car battery we have and stupidly put the jumper cables on the spare battery backwards. Alternator wire started smoking but I quickly noticed and fixed the issue. Once the cables were on right I went to start the bike and it started right up with no issues, so I don't think this is my problem, but I am including just because it is a possibility.
Went for an hour and a half ride to see if the battery would hold a charge, it didn't, so I bought a new battery and swapped it out. Other than the battery not holding a charge the bike ran really well. After sitting overnight, the bike had trouble starting cold and only started about half the time, and had trouble idling cold (wouldn't idle at low idle but would poorly at high idle), but the fuel pump was running and the bike would start. This was a problem last year as well so I think that there's a new issue. Now, the next day, the bike doesn't turn on at all and there is no power coming to the fuel pump.
The fuse seems to be in working order as I swapped it with a known good one and there is no power at either end of the fuel pump fuse when cranking. I put a wire from the positive end of the battery to the fuel pump fuse and the fuel pump does work. I think that I tested the fuel pump relay correctly and I was getting +12v to pin #86, -12v to pin #85, and +12v to pin #30 with the key on as per this post: https://www.k100-forum.com/t1686-fuel-pump-not-powering-up The only discontinuity I have with the information in that post and my relay is that pin #30 was only getting power with the key on and wasn't powered with the key off.
I am a complete novice when it comes to diagnosing, and I have no idea where to go from here.
Thanks for your help in advance
