1 Welded gastank and now the pump won't start Sat Apr 10, 2021 12:57 pm
Carlsen
Hi.
Had the pinhole leak beside the pump.
Sent the tank to a welder, didn't take anything off. Wire and pump still in.
Also changed the filter when I had washed the tank.
Now a few months later, it won't start.
Can the electricity from the weld f****ed it up?
I tried to start it with gas lid open and didn't see or hear anything. Got 12v to the connector.
Didn't fill the New filter with petrol, didn't need to? If the pump had worked it would fill the filter?
Going to clean up and grease the ground point under the tank tonight, hope it would be that easy
