Go to page : Previous  1, 2
51Back to top Go down   Fuel Pump Not Powering Up - Page 2 Empty Re: Fuel Pump Not Powering Up Sat May 26, 2018 12:06 am
GregC wrote:Even though an old thread I found it really informative and useful for chasing a fault on my K100.
Why don't you share the tale of your chase here, Greg, and tell us where it led you? It might inspire somebody to avoid setting a match to a stubborn K for insurance purposes.
52Back to top Go down   Fuel Pump Not Powering Up - Page 2 Empty Helped stop chasing a red herring Sat May 26, 2018 1:47 am
GregC
GregC
I recently found some corrosion in tank, so removed it for repair. While tank was off i decided to fit a VDO fuel gauge . I wired the the gauge into the part of the harness that goes to the fuel sender:  Green 12v, Brown ground, yellow sender, white low fuel light. Anyway with ignition on the gauge   would not operate and there was no longer 12v on green!
So the value  in this thread was the knowledge that the fuel pump does not have power all the time ignition is on , hence lack of 12v on green was not actually a fault!
53Back to top Go down   Fuel Pump Not Powering Up - Page 2 Empty Re: Fuel Pump Not Powering Up Sat May 26, 2018 4:12 am
GregC wrote:While tank was off i decided to fit a VDO fuel gauge . I wired the the gauge into the part of the harness that goes to the fuel sender:
Bit late but...under the tank you find a own connector for the fuel gauge.
Fuel Pump Not Powering Up - Page 2 Kontak12
54Back to top Go down   Fuel Pump Not Powering Up - Page 2 Empty Re: Fuel Pump Not Powering Up Sat May 26, 2018 9:29 pm
Is that connector on all wirring looms ?
I would like a better gauge on mine than just the lights on the dash
Plus a water temp gauge
55Back to top Go down   Fuel Pump Not Powering Up - Page 2 Empty Re: Fuel Pump Not Powering Up Sun May 27, 2018 4:58 am
Matthew-Brisbane wrote: Is that connector on all wirring looms ?
All is present exept for the wire to the water temp sensor.
If have the OEM gauges in mind, it's also a intermediate wiring needed.
If you have a -83 -85 model the connector looks a bit different, and it
haven't any connector for the fuel level gauge as a different sensor is used.
56Back to top Go down   Fuel Pump Not Powering Up - Page 2 Empty not too late Thu May 31, 2018 8:53 am
GregC
GregC
Matthew-Brisbane wrote:Have now used that connector, thanks for ID'ing it.
57Back to top Go down   Fuel Pump Not Powering Up - Page 2 Empty Re: Fuel Pump Not Powering Up Sat Jun 02, 2018 4:10 pm
ReneZ
ReneZ
Hi Greg, depends on the age of the bike and its equipment. The early bikes had a standpipe with two sensors, which doesn't allow fitting a fuel gauge. Younger models with a float in the tank should allow that. Put your bike details in your signature and we can respond better :-).
Cheers, Rene
Rene
BMW K100 - 1985 (0030029) Scotland Fuel Pump Not Powering Up - Page 2 Rain
58Back to top Go down   Fuel Pump Not Powering Up - Page 2 Empty Re: Fuel Pump Not Powering Up Sat Jun 02, 2018 5:01 pm
Bite your tongue Laitch, have you been associating with the Dark Side ( HOG). No Brickian should ever suggest doing an insurance job on a poor unsuspecting Brick. Shame shame shame. Now go forth and repent your sins and consider resurrecting a poor neglected one. Fuel Pump Not Powering Up - Page 2 161205 Fuel Pump Not Powering Up - Page 2 167893
Regards a shocked Martin.
59Back to top Go down   Fuel Pump Not Powering Up - Page 2 Empty Re: Fuel Pump Not Powering Up Sat Jun 02, 2018 6:20 pm
MartinW wrote: Now go forth and repent your sins and consider resurrecting a poor neglected one.
Fuel Pump Not Powering Up - Page 2 Il_57010
Been there; done that; got the T-shirt and when it turned out to be a V-neck, I backslid immediately and it was repossessed.
60Back to top Go down   Fuel Pump Not Powering Up - Page 2 Empty Re: Fuel Pump Not Powering Up Sat Jun 02, 2018 6:38 pm
I'm with you on the "V" necked "T" shirts. Fuel Pump Not Powering Up - Page 2 797640 I'll leave the wearing of those to my better half.
61Back to top Go down   Fuel Pump Not Powering Up - Page 2 Empty Re: Fuel Pump Not Powering Up Thu Jun 14, 2018 4:29 am
MarcS
MarcS
I wonder if the OP ever got his bike to run?????
62Back to top Go down   Fuel Pump Not Powering Up - Page 2 Empty 84 k100 fuel pump Sun Oct 28, 2018 3:09 pm
rayban1
rayban1
Hello all..this seemed like a good place to ask about no start problem
Starter works but I dont think the pump is working. I have 10.9 v at wht/grn and brn wires on the pump plug when I push starter, but I dont hear the pump turning. Does that mean the pump is bad or could it be another problem ?
63Back to top Go down   Fuel Pump Not Powering Up - Page 2 Empty Re: Fuel Pump Not Powering Up Sun Oct 28, 2018 5:42 pm
The 4 pin connector from the tank to the harness is a frequent culprit in pump running problems.
64Back to top Go down   Fuel Pump Not Powering Up - Page 2 Empty Re: Fuel Pump Not Powering Up Sun Oct 28, 2018 6:33 pm
rayban1 wrote:Hello all..this seemed like a good place to ask about no start problem
Can I suggest that a new thread is a better place to start? Tagging on to an old thread, even with a similar problem, can result in losing track. Smile
As point seven five said, ensuring good continuity at the 4 pin connector is a good first step.
65Back to top Go down   Fuel Pump Not Powering Up - Page 2 Empty Re: Fuel Pump Not Powering Up Mon Oct 29, 2018 1:12 pm
rayban1
rayban1
Ok Indian ... thanks..... Ill try that !
