1Back to top Go down   K100LT has no gas gauge Empty K100LT has no gas gauge Sat Nov 28, 2020 9:31 am
DanT56
DanT56
The '87 I'm picking up does not have a gas gauge. Can these be added?
2Back to top Go down   K100LT has no gas gauge Empty Re: K100LT has no gas gauge Sat Nov 28, 2020 10:00 am
Yes, most of what you need is on eBay. They're usually paired with a temperature gauge.
On the LT, the gauges are on a crossbar above the instrument cluster. Figure a couple hundred for all the parts to add them. For some reason, it's easier to find what you need if you look for parts from a K1100LT too. They're interchangeable.
3Back to top Go down   K100LT has no gas gauge Empty Re: K100LT has no gas gauge Sat Nov 28, 2020 2:09 pm
DanT56
DanT56
That's good to know, thanks.
4Back to top Go down   K100LT has no gas gauge Empty Re: K100LT has no gas gauge Sat Nov 28, 2020 2:53 pm
There are any number of dealer and other sites to use to look up the part numbers you need. My favourite is www.realoem.com but dealers like Bob's BMW. Max BMW, South Sound Motorcycles, and others have links to BMW's ETK (Elektronik Teile Katalog).
Here's a link to real OEM:  Real OEM BMW Motorcycles US Models
If you have any specific questions about how to use BMW's catalogues or how the part numbering system works, ask away. There are many obliging members on this forum.
One other bit of advice that is useful to others when you're asking questions, is for you to go to the Signature line in the Profile tab above and add your year and model, even the last seven digits of the VIN to your profile, so we know what it is you're talking about without having to search back through your posts to see what model you might have mentioned days or weeks ago.
5Back to top Go down   K100LT has no gas gauge Empty Re: K100LT has no gas gauge Sat Nov 28, 2020 5:21 pm
If you don't have the instrument cross bar the panel that is under it [behind the cluster] is marked on the rear face for the cut outs. So I discovered on my K100LT.
6Back to top Go down   K100LT has no gas gauge Empty Re: K100LT has no gas gauge Sun Nov 29, 2020 9:36 am
DanT56
DanT56
Thanks TWB for the info and my bike info should be added now.
1987 K100LT
7Back to top Go down   K100LT has no gas gauge Empty Re: K100LT has no gas gauge Sun Nov 29, 2020 9:38 am
DanT56
DanT56
92KK 84WW Olaf wrote:If you don't have the instrument cross bar the panel that is under it [behind the cluster] is marked on the rear face for the cut outs. So I discovered on my K100LT.
There is a shelf just about the dash but I'm not sure if that is what you are referring to but I'll look into it.
1987 K100LT
