1Back to top Go down   Final Drive Pinion Tool Empty Final Drive Pinion Tool Sun Nov 15, 2020 5:46 pm
dwnhillskater
dwnhillskater
Does anyone in the Seattle area happen to have the final drive pinion tool that would be willing to loan it out? If not, anyone anywhere willing to loan it if I pay for shipping?
Would be greatly appreciated!
Aaron
2Back to top Go down   Final Drive Pinion Tool Empty Re: Final Drive Pinion Tool Sun Nov 15, 2020 6:19 pm
Boxer2Valve.com
In the above link you'll find the specs to make one or to have one made for you. Some people weld a large nut to the pipe, others drill a hole for a T-bar. Mechanical advantage is a good thing.
3Back to top Go down   Final Drive Pinion Tool Empty Re: Final Drive Pinion Tool Sun Nov 15, 2020 7:40 pm
As per TWB  good leverage but you definitely need to heat it up to the required temperature to get the nut to crack. Tried two heat guns but it took a gas torch to get enough heat into it.
4Back to top Go down   Final Drive Pinion Tool Empty Re: Final Drive Pinion Tool Mon Nov 16, 2020 5:27 pm
