1Back to top Go down   Tranny fluid leak Empty Tranny fluid leak Sat Sep 26, 2020 4:44 pm
zaubertuba
zaubertuba
I thought I may have had a drop or two when the bike's been sitting awhile, but while I've been working on the handlebars, I've had this:
Tranny fluid leak Trlk210Tranny fluid leak Trlk110
It smells like tranny fluid.  Did I have a seal go out, or does this have anything to do with the fact I've got the clutch cable disconnected?
1985 K100RS
2Back to top Go down   Tranny fluid leak Empty Re: Tranny fluid leak Sat Sep 26, 2020 6:00 pm
zaubertuba wrote:. . . does this have anything to do with the fact I've got the clutch cable disconnected?
That is likely. Read this .
3Back to top Go down   Tranny fluid leak Empty Re: Tranny fluid leak Sun Sep 27, 2020 6:59 am
If you're really lucky the boot has pulled off the back of the gearbox and can be reused, but my bet is on it having ripped where it sits up against the clutch arm. New boot time Sad . If you ever need to disconnect the clutch cable, always tie the clutch arm to the frame. It just needs to be at the point where it engages with the clutch.
4Back to top Go down   Tranny fluid leak Empty Re: Tranny fluid leak Sun Sep 27, 2020 12:10 pm
gorio
If the boot is torn you maybe able to repair it.
I tore about a 3/8" long slit in one and the replacement was going to be a while coming.
I happened to have some Aquaseal wet suit repair adhesive in the freezer. After cleaning the seal up good applying the sealer and letting it dry over night the repair looked pretty good.
Beening on the RS 4valve you pretty much need to drop the exhaust to replace the boot I have left the repaired boot on it until it leaks or I drop the exhaust for other reasons.
So several months and a few thousand K later it is still sealed up.
Hopefully yours has just slipped off and is not damaged.
1992 K100rs 16v
1997 R1100rt
2006 R1200rt
Past lives
Kawasaki Concours
1976 BMW R90s
1975 Ducati 860gt
1992 Honda VFR750
1985 Honda VF750
1982 Kawasaki 750GPZ
1975 Norton 850 Commando
5Back to top Go down   Tranny fluid leak Empty Re: Tranny fluid leak Sun Sep 27, 2020 12:43 pm
Suzi Q
Suzi Q
I got so fed up of forgetting about the clutch boot every time I disengaged the cable, that I kept a long-standing promise to myself and made this bracket so's I no longer represented a threat to the world's supply of replacement clutch boots:
Tranny fluid leak 00519
I do seriously think there's a design fault in there somewhere - with the owner, not the bike....
Last edited by chris846 on Sun Sep 27, 2020 12:44 pm; edited 1 time in total (Reason for editing : having trouble spelling, agani)
6Back to top Go down   Tranny fluid leak Empty Re: Tranny fluid leak Sun Sep 27, 2020 4:28 pm
A small slip of flexible leather and some shoe goo or other sloopy sloppy glue works a charm over a torn clutch boot if you can't easily get one and/or don't have time to do it then and there.
