1 Sprag clutch fixed... engine starts but is sick.. what have I done? Thu Nov 19, 2020 2:01 pm
V11POW
Hello from Christchurch, Dorset.
My sprag clutch was stuck so I followed the excellent posts on here to free it off using Seafoam sprayed into the three holes.
I used 5th gear to rotate the crank manually via rear wheel.
After a couple of days of heating and spraying the engine turned again on the button.
Oil back in, plugs cleaned and connected. The motor fired on the button, but was running very erratically. It picks up okay on the throttle but dies pretty quickly on no throttle.
I tried opening the tank cap - no difference.
Re-checked the plugs. All okay..
I rode it into the garage before the sprag issue, so it was running perfectly well for a 90,000 miler.
What on earth have I done by freeing the sprag?
Thanks for reading this far..
Neil.
Neil.
