1Back to top Go down   Mind the gap Empty Mind the gap Mon Jul 27, 2020 10:17 pm
stanthomas
stanthomas
This gap:
Mind the gap Y4mW7Rwq-nLd9brmLdkzgMGBldFQHsYH2iUrKFbmjavh-C-sDv7DbIQiGbmowYTcZbRElL5itBbYkQgo7tbRj24rLoujwsl0AZ4-_piGFzQjrt8HTZH9tQkYcCYp2NY7oraITnvhUK8jHTTS1GaC0GSlGKTgJMkfOv7rX6l3VYDY3R5Lyi-_z5Yr5Ueybo57ZH_o05I4hPIEbQynBtB7Tffmg?width=660&height=371&cropmode=none
Betwixt side panel and rear unit:
Mind the gap Y4mIV3C2CZD_ybsjkOwf00eFVP8PkExiks0Ld4ueiY1YF5b6vPtXSYrrRUSkJjEPQ-J7JiGnkIOHXEFdkkrbOPYqb0i9v1tlCbYyHTmzCs5GMXhGaYGTeSzDAgzkauuQKTiEn8A536KMLcyor7fcKt0_ecE12VBJ2FJnpmz0K_K74LVIKk3KeSzF66UKzm8eyf3K8Z_KA-xLWLsuoUWEWSptw?width=660&height=371&cropmode=none
Need to close it up by 20mm for a good fit. I note that this gap seems to be present in all K pictures, even on the front of the Clymer manual. But mine's so bad the side panel peg doesn't stay located in the rear unit.
Before I start filing slots in the rear unit mountings, am I missing something?
'91 K100RS 16V
2Back to top Go down   Mind the gap Empty Re: Mind the gap Tue Jul 28, 2020 2:50 am
All my K's have it also, and lots of K's I've seen.
Mind the gap Eu-log10  K1100RS/LT - R1200RT - R1100RS - Cagiva SST 350 Ala Verde - K75LT project - K75 Schurgers - K75S - K1100RS - K75RT - K75C
3Back to top Go down   Mind the gap Empty Re: Mind the gap Tue Jul 28, 2020 9:17 am
Arlina wrote:All my K's have it also, and lots of K's I've seen.
As well as every K that has passed through my garage.  Some gaps have been quite large.
4Back to top Go down   Mind the gap Empty Re: Mind the gap Wed Jul 29, 2020 8:19 pm
yankeeone
My 86 k100 has "doesn't look right" gap as well, not quite that extreme.
5Back to top Go down   Mind the gap Empty Re: Mind the gap Thu Jul 30, 2020 7:43 am
Bonzo
Bonzo
We all have 'the gap', but that looks too much.  scratch
1990 K100RS 4V (VIN# 6406682)
2017 R1200RS SE Sport
6Back to top Go down   Mind the gap Empty Re: Mind the gap Thu Jul 30, 2020 7:49 am
I would check the position of the seat hump. The fibron wears over time and if the hump has been removed at any point, it's possible that it's been replaced as the rearmost position. The alternative is that the fuel tank can be moved back. You have a gap between the seat and that tank which suggests either the hump or the tank is not in the optimum place.
