1Back to top Go down   Warped discs from corrosion Empty Warped discs from corrosion Thu Jul 22, 2021 9:36 pm
Snod Blatter
Snod Blatter
Hi all, I've had some warped discs on my K for a while now, it's so bad that it knocks the pads away and I have to pump the front lever to be able to stop! I assumed it was rust on the (cast iron) discs again, but looking closer I see that it's actually probably caused by some serious corrosion between the carrier and the outer disc. Observe:
Warped discs from corrosion SBFcaTZ
Has anyone else experienced this? It's from the salt in the winter, and sitting outside.. I now have a garage for her to live in ( cheers ) but I'm too late to stop this from happening.
Is the carrier salvageable if I take it to bits and wire brush it? It seems like it'll be a lot of work, the little nuts for the disc refuse to budge with an open ended spanner on them so I'll have to get a socket on them, but to do that I have to remove the ABS ring and I have a strong suspicion it's gonna fight me all the way!
Alternatively, if anyone has some nice non-rusting ABS discs for sale, I might be tempted.. Even better if they're those fancy EBC semi floaters Warped discs from corrosion 652573
2Back to top Go down   Warped discs from corrosion Empty Re: Warped discs from corrosion Fri Jul 23, 2021 12:46 am
If its 8v K I don t think they float. I have EBC on one of mine.
3Back to top Go down   Warped discs from corrosion Empty Re: Warped discs from corrosion Fri Jul 23, 2021 1:04 am
I bought these about 6 + years ago from Motorworks UK. Ordered on Monday they arrived on Friday, from memory they were on special $400.00 Au including freight. I don't have ABS and still waiting to use them.
Warped discs from corrosion P7230010
Warped discs from corrosion P7230011
4Back to top Go down   Warped discs from corrosion Empty Re: Warped discs from corrosion Tue Jul 27, 2021 1:16 am
Snod Blatter
Snod Blatter
No one else has abused their bike this badly? Just me? Dang it..
5Back to top Go down   Warped discs from corrosion Empty Re: Warped discs from corrosion Tue Jul 27, 2021 1:37 am
I've had a pulsating problem twice in 20 years. I have successfully straightened warped discs. We are talking minor warping not major buckles. If you don't have patience and restraint read no further and get another disc. Be warned it is a slow process requiring lot's and lot's patience and a delicate touch, and only works on solid rotors not floating ones. Set the bike up so the front wheel is off the ground. You need to remove the calipers and attach a dial gauge indicator (DGI) with whatever you can rig up solidly to the top caliper retaining bolt. It needs to be set up so it runs on the outer most edge of the disc, and can be rotated away from the disc when adjusting the warp. This will only work if the disc has a smooth track to run on, if it doesn't forget it. With the DGI set up to run on this track rotate the disc a determine where the warp is and how big it is and mark with a pencil this part will be repeated after each adjustment. To remove the warp you will need a piece of  broom handle 10" - 12" long and a plastic hammer. The next bit requires patience and a delicate touch. Rotate the DGI so it is clear of the disc and place the end of the broom handle on the outer most edge of the disc carrier (not on the disc) where you marked the position of the warp, and tap gently with the plastic hammer.  If the warp is bulging out from the centre you need to tap it in. If it is bulging in need to tap it out. When tapping it out, the broom handle will be running at an angle this is the reason for it's length. You need to realign the DGI after every tap and check that you have moved it and by how much. Under no circumstances belt it or hit it hard, you will eventually get a feel as to how hard to tap it believe me it won't be a lot. Hitting it hard will only push it too far and will require you to tap it back the other way. You need to avoid tapping it to and fro, this will happen occasionally but needs to be reduced to the minimum. You are aiming for a figure under .007", well under this can be achieved with patience.
Warped discs from corrosion Bmw_ro11
