1Back to top Go down   Repair Hi/Lo beam switch Empty Repair Hi/Lo beam switch Thu Oct 22, 2020 4:08 pm
waneill
waneill
Another way to repair the Hi/Lo switch after taking it apart is to use a dremmel like tool to carefully grind out the plastic housing around all of the electrical contacts.  Harbor Freight sells a Dremmel like took for a little over $10 that comes with many small cutting tools.  One of these tools is a small bur about 3 mm in diameter.  This tool works well to grind the switch housing.  I found that grinding about 0.010 inches or 1/4 mm works well.  This method avoids melting the plastic and pushing the contacts in further.
I live in Montclair, CA and would be happy to assist anyone repair their switch.
2Back to top Go down   Repair Hi/Lo beam switch Empty Re: Repair Hi/Lo beam switch Fri Oct 23, 2020 4:56 am
Dropped this post in the right section for you Cool
Repair Hi/Lo beam switch Eu-log10  K1100RS/LT - R1200RT - R1100RS - Cagiva SST 350 Ala Verde - K75LT project - K75 Schurgers - K75S - K1100RS - K75RT - K75C
