1 lube shock mounts Fri Jul 17, 2020 2:24 pm
tinyspuds
After a clean up I’m going to reinstall the original hagons to my leading links. Question: Should I lube the mounting bolts? I’m seeing conflicting advice about do it or not. In the past I’ve slapped axle grease onto the bolts, which I think now has been pretty useless. I’m minded to use a bit of the high moly content lube that I use for the splines. Thoughts please?
