1Back to top Go down   Ignition live cable rating Empty Ignition live cable rating Thu Jul 09, 2020 12:18 pm
BooG
BooG
The live red cable running from the starter relay up to the ignition barrel...what is the amp rating of that cable please?
Thanks.
2Back to top Go down   Ignition live cable rating Empty Cable rating Fri Jul 10, 2020 3:44 am
daveyson
daveyson
What's the go, do you want a siren, police lights and cb, or something like that?
I measured 100 Amps on mine with a stall test. Dunno how relevant that is though.
 ~120,000 km
3Back to top Go down   Ignition live cable rating Empty Re: Ignition live cable rating Fri Jul 10, 2020 8:34 am
Not likely to be more than 33amp @ 12 volt rating. The K loom is load-distributed i.e. not all of the power goes through the ignition switch - see the load shed relay, for example, which provides power to the lights, indicators and horn. When rewiring I've only ever used a 25amp cable on that run and never had any trouble.
4Back to top Go down   Ignition live cable rating Empty Re: Ignition live cable rating Fri Jul 10, 2020 9:04 am
Suzi Q
Suzi Q
The 1984 handbook wiring diagram shows a 2.5mm red wire from the starter relay COM terminal 30, which goes to a loom junction and there splits and goes to various loads. One of these loads is a 1.0mm red wire to the ignition switch. This might be the wire you're on about.
If you're after adding the 'police sirens' etc (  Smile ) i.e. extra loads on this red wire, then its load capacity/max current can be calculated in theory, but it depends on de-rating factors such as ambient temperature. I'd suggest that the aged condition of the end terminations/ignition switch contacts etc. is a factor too, especially if you're getting near the limit. It is therefore not usually practical to do anything better than a good guesstimate, as Dai has done, and then play safe - you want wires not heating elements!
Best thing is to describe what you've got in mind and you'll get good advice on here. Safest route for add-ons is usually spangly new wire from the battery, a fuse and a relay.
5Back to top Go down   Ignition live cable rating Empty Re: Ignition live cable rating Fri Jul 10, 2020 9:59 am
Best advice there- means no interference to the factory electrics and easy trouble shooting.
6Back to top Go down   Ignition live cable rating Empty Re: Ignition live cable rating Sat Jul 11, 2020 10:48 am
chris846 wrote:The 1984 handbook wiring diagram shows a 2.5mm red wire from the starter relay COM terminal 30, which goes to a loom junction and there splits and goes to various loads. One of these loads is a 1.0mm red wire to the ignition switch. This might be the wire you're on about.
So... it appears I really, really believe in overkill. 1.0mm.sq PVC (which is what the original is) has a current rating of 8.75amps @ 12 volts. Makes sense. Trace the green wire back down through the loom and essentially it's only providing power for the load distribution relay coils. And a little bit else.
Next one I do only gets a 16.0amp cable for that feed bounce Very Happy
In truth, there's also the mechanical strength aspect to consider. I could run an 11amp cable to the ignition switch which would be more than adequate power-wise, but I'd prefer the increased stength of a 16amp cable in an area that gets a lot of movement.
7Back to top Go down   Ignition live cable rating Empty Re: Ignition live cable rating Sun Jul 12, 2020 7:03 am
BooG
BooG
That’s great info from everyone...thanks!
I am repairing damage to the cable from when my K75S was recently stolen. I am not adding anything else to the load regarding electrics. I just want to run a new cable rather than repair the old one.
