1 Gearbox front sealing plug Thu Jul 02 2020, 12:32
Scouser
Sorry if this has been asked before. I couldn't find the answer.
K100 gearbox front cover: I'm going to heat the cover to 100 degrees to drop out the input shaft tapered bearing race. The front sealing plug hasn't been leaking and doesn't carry a shaft so I thought I could leave it alone.
Should I replace it because I'm going to heat the case? If so, how do I remove the disc with the spigot that feeds oil to the centre of the gearbox output shaft? It's tight and I can't see how it's held in.
While we're at it, should the seal for the gear position sensor at the back of the box be replaced, again given that the box will be heated, or would gasket goo against the switch do the job?
Help will be much appreciated. Many thanks!!
