1Back to top Go down   16v brake disc thickness (F&R)? Empty 16v brake disc thickness (F&R)? Sat May 23, 2020 5:04 am
Bonzo
Bonzo
H all,
I've borrowed a micrometer to check my disc brakes.
Can anyone tell me what the minimum thickness should be for front & rear please?
16v ABS.
1990 K100RS 4V (VIN# 6406682)
2017 R1200RS SE Sport
2Back to top Go down   16v brake disc thickness (F&R)? Empty Re: 16v brake disc thickness (F&R)? Sat May 23, 2020 6:22 am
Should be readable on the disk inner, quick check says 4,5mm on mine.
16v brake disc thickness (F&R)? Eu-log10  K1100RS/LT - R1200RT - R1100RS - Cagiva SST 350 Ala Verde - K75LT project - K75 Schurgers - K75S - K1100RS - K75RT - K75C
3Back to top Go down   16v brake disc thickness (F&R)? Empty Re: 16v brake disc thickness (F&R)? Sat May 23, 2020 6:29 am
Bonzo
Bonzo
Cheers Arlina,
Didn't realise it was on the disc itself.
4Back to top Go down   16v brake disc thickness (F&R)? Empty Re: 16v brake disc thickness (F&R)? Sat May 23, 2020 7:00 am
Never too old to learn Smile
5Back to top Go down   16v brake disc thickness (F&R)? Empty Re: 16v brake disc thickness (F&R)? Sat May 23, 2020 3:39 pm
Bonzo
Bonzo
It seems my fronts have life left in them, but the rear is down to 4134mm so looks like I'll be doing some spending   Twisted Evil
6Back to top Go down   16v brake disc thickness (F&R)? Empty Re: 16v brake disc thickness (F&R)? Sat May 23, 2020 4:36 pm
That's a big disc!!!!! affraid
7Back to top Go down   16v brake disc thickness (F&R)? Empty Re: 16v brake disc thickness (F&R)? Sat May 23, 2020 4:40 pm
Bonzo
Bonzo
Very Happy  it should last for ever!
8Back to top Go down   16v brake disc thickness (F&R)? Empty Disc thickness Sat May 23, 2020 8:21 pm
daveyson
daveyson
So sposing ~4.1mm
Spose not too much of a hijack, one of my spare bricks has a rear disc thickness of 1.6mm. I recon I'd win a contest for the thinnest disc, hard to believe it could get to that without warping or cracking, so I'm keeping it as a souvenir.
 ~120,000 km
9Back to top Go down   16v brake disc thickness (F&R)? Empty Re: 16v brake disc thickness (F&R)? Sun May 24, 2020 1:52 am
Put it on a chain and wear it around your neck you never know when the seventies will return. 16v brake disc thickness (F&R)? 652573
10Back to top Go down   16v brake disc thickness (F&R)? Empty Re: 16v brake disc thickness (F&R)? Sun May 24, 2020 2:02 am
MartinW wrote:. . . you never know when the seventies will return.
idea2 2070?
11Back to top Go down   16v brake disc thickness (F&R)? Empty Disc thickness Sun May 24, 2020 2:30 am
daveyson
daveyson
Be good to stretch an ear piercing.
 ~120,000 km
