Number of posts : 7963
Snod Blatter wrote:I've also had head shakes when on overrun at those speeds, and it gets
worse as the tyres wear out. One time I had a Metzeler Lasertec on the front which was simply horrendous..
So, what pressures are you running and what kind of tread depth have you got left?
I had 2 Ks that POs had Lasertecs on them. Absolutely horrific tyres and found them really bad in rain.
After that, all got BT45. I set the K100LT on cruise on motorway and did about 5 miles hands off using slight body weight shift to steer. Steady as a rock, head bearings and rear shock and rear tyre all known to be good at the time and not carrying much. Too much weight biased to the rear can cause shake too.
1971 Yamaha 125 YAS-1
