1Back to top Go down   Look what I found in my tank... Empty Look what I found in my tank... Fri Sep 23, 2011 3:31 pm
purkolator
Went to pull the tank off to give myself a bit better access to some hoses I wanted to replace. I took a peed inside and noticed a tool hanlde... Hmmm... Pull it out to find this...
Look what I found in my tank... IMG_20110922_132440
A few weeks ago I was on my way home from work and the bike died. Since I was only a few blocks from my mechanic I dropped it with him to suss out. He found a hose clamp had come loose from the fuel pump, reattached it and sent me off N/C. Looks like he got a bit lazy about putting his tools away tho...
Well, new 9mm flex driver for me!!! Wheee!
Brad
2Back to top Go down   Look what I found in my tank... Empty Re: Look what I found in my tank... Fri Sep 23, 2011 6:04 pm
g35corona
g35corona
That mechanic is probably going insane wondering where he left that driver. Although after a certain age, you just kind of accept that things disappear.....it's a mystery.
Bob
;BMW;
ex:1986 K100 RT Vin #0091835
2012 R1200 GS
3Back to top Go down   Look what I found in my tank... Empty Re: Look what I found in my tank... Fri Sep 23, 2011 6:07 pm
woohoo ...win !!!
purk .....does this mean the end of your woes ?
4Back to top Go down   Look what I found in my tank... Empty Re: Look what I found in my tank... Fri Sep 23, 2011 6:10 pm
Didn't I just read on News of the Weird about some large surgical tool that had been left inside of a patient for twenty years!?
"Now where is that damned intramedullary kinetic bone distractor? I had the bloody thing a moment ago!"
5Back to top Go down   Look what I found in my tank... Empty Re: Look what I found in my tank... Fri Sep 23, 2011 6:16 pm
Look what I found in my tank... 44271
6Back to top Go down   Look what I found in my tank... Empty Re: Look what I found in my tank... Fri Sep 23, 2011 7:12 pm
purkolator
@Charlie99 - no.. the woes continue. My used AFM unit shows up today so I'll be popping that in either tonight or tomorrow and see what that does. If that doesn't do the trick, I'm going to pull the injectors and get a better idea of what they are doing.
7Back to top Go down   Look what I found in my tank... Empty Re: Look what I found in my tank... Fri Sep 23, 2011 7:16 pm
sure is weird behaviour all the same
good luck mate
8Back to top Go down   Look what I found in my tank... Empty Re: Look what I found in my tank... Sat Sep 24, 2011 7:57 pm
Man that's given me another good idea, I know where to keep my emergency tool kit now, won't have to open up the seat.
Let's see, spare clutch and brake cables, relays and socket set.
