Albyalbatross1
Albyalbatross1
I finally got tired of my starter engaging after two or three tries...So I Cleaned it! Here is what i did for those who are interested.
First do THIS!!!
Sprag Clutch & Cleaning the Sprag clutch and bearing replacement. 1this_12
I removed my intermediate housing or leave it on for this next step. Loosen off the bolt hoding the alternator drive. you will need to wedge the drive to undo the bolt. I ended up using a socket as the wood kept crushing.
Sprag Clutch & Cleaning the Sprag clutch and bearing replacement. 2_rele10
Then using a bearing puller I had ground the claws down on I pulled the drive up a bit at a time until it would just pull out.
Sprag Clutch & Cleaning the Sprag clutch and bearing replacement. 3_bear10
This is where you can remove your auxiliary housing if you left it on the engine and remove the freewheel and counter shaft.
Once the Freewheel was on the bench i could see the residue from 30 yrs oil
Sprag Clutch & Cleaning the Sprag clutch and bearing replacement. 4_resi10
Removed the gear wheel from the clutch and auxillary shaft they just gently pull apart. Then remove the 6 bolts holding the covering plate over the gear wheel. Then set the gear wheel on the bench and Gently pries the sprag clutch out.
Sprag Clutch & Cleaning the Sprag clutch and bearing replacement. 6_out_10
Here is my gummed up sprag. Be very care full not to dislodge any of the lobes. They are held in by a very small fine spring.
Sprag Clutch & Cleaning the Sprag clutch and bearing replacement. 8_gumm10
The Very Fine Springs
Sprag Clutch & Cleaning the Sprag clutch and bearing replacement. 10_lil10
Now put it in a small tray of solvent to soak for a bit. I should have placed it back in the ring to clean it as I managed to knock some of the lobes out. Use a toothbrush or whatever yu fancy. Once its all clean start to put it back together.
Put the ring on auxillary shaft, spacer ring in next followed by some oil and the sprag clutch. be sure its the right way around!
Sprag Clutch & Cleaning the Sprag clutch and bearing replacement. 16_spa10
Then some more oil and then the cover plate and bolts. Torque up to spec..
Sprag Clutch & Cleaning the Sprag clutch and bearing replacement. 17_tor10
Next I did the bearings in the Gear Wheel. These came out easily enough with a tube socket as a drift and with some heat..
Sprag Clutch & Cleaning the Sprag clutch and bearing replacement. 5_out_10
Time for Coffee!!!!!!! Cheeky Cafe Staff!!
Sprag Clutch & Cleaning the Sprag clutch and bearing replacement. 12_che10
I used a length of threaded rod I had lying about to pull the new bearings in.
Sprag Clutch & Cleaning the Sprag clutch and bearing replacement. 14_bea10
New Bearings in place. be sure to take them in far enough.
Sprag Clutch & Cleaning the Sprag clutch and bearing replacement. 15_new10
Now oil the sprag clutch through the holes in the ring and oil the Auxilary shaft and the gear wheel bearings.
Sprag Clutch & Cleaning the Sprag clutch and bearing replacement. 18_oil10
Sprag Clutch & Cleaning the Sprag clutch and bearing replacement. 19_oil10
Then gently twist the auxiliary shaft into the sprag clutch turning the same way as the lobes point and it should just slide right back in.
I then did a naughty thing and cleaned the threads up.(might want to do this first! then clean things up)
Sprag Clutch & Cleaning the Sprag clutch and bearing replacement. 20_thr10
Thats it for this bit. Next the bearing and seal for the intermediate housing and the bearing in the engine block for the auxiliary shaft.
Sprag Clutch & Cleaning the Sprag clutch and bearing replacement. 21_all10
To replace the bearing in the block for the auxiliary shaft you will need a blind bearing puller. (good sets for 30 bucks in aus)This is how it comes out. I then made a drift up to drive the new one home from a large bolt i linished down to size.
Sprag Clutch & Cleaning the Sprag clutch and bearing replacement. 29_out10
Next I replaced the bearing /seal in the Intermediate housing. It was easy to remove if you follow the instructions in your haynes manual.
Sprag Clutch & Cleaning the Sprag clutch and bearing replacement. 22_new10
Bearing
Sprag Clutch & Cleaning the Sprag clutch and bearing replacement. 23_new10
Torque/Loctite
Sprag Clutch & Cleaning the Sprag clutch and bearing replacement. 24_tor10
Put it all back together
Sprag Clutch & Cleaning the Sprag clutch and bearing replacement. 25_sea10
Torque the drive bolt up...
Sprag Clutch & Cleaning the Sprag clutch and bearing replacement. 26_tor10
All done. Do not forget to put the counter shaft in before you torque things up Embarassed Embarassed This solved my problem of a spinning sprag clutch. I changed the bearings because I was in there. I am still on the trail of a small rattle !!!!!
Last edited by Albyalbatross1 on Tue 24 Jul 2012, 00:03; edited 1 time in total (Reason for editing : ..)
Lazyboy
Lazyboy
Excellent how to and photos ! I think you should write a manual " K Bikes For DUMMIES "
1984 BMW K100RT
Bikes Name: Lazyboy
great post alby ...
man..... you have done things many of us just dream of doing ....
cheers !!!
charlie99 wrote:great post alby ...
cheers !!!
+1 Alby - Such clarity would inspire confidence in even a ludite like me tackling the job.
Moderator....move to "How to" section please!
88KE
Sprag Clutch & Cleaning the Sprag clutch and bearing replacement. Ir-log1188....May contain nuts!Sprag Clutch & Cleaning the Sprag clutch and bearing replacement. Ir-log11
K75RTP - 1994
done ...great post !
BIG D
BIG D
Cool
Top job Alby, thats a good write up many thanks.
BIG D
kfilipow
kfilipow
Thanks Alby. I agree with 88KE
kf
krambo
krambo
A great and informative post Alby - thanks so much Wink
"Aut viam inveniam aut faciam." Sprag Clutch & Cleaning the Sprag clutch and bearing replacement. Uk-bmw12
http://www.its-personal.net
Oldgoat
Oldgoat
Outstanding pics Alby! Cool
OG
After knocking out some Pawls I found the best way to handle them is to use some dental floss to hold the tiny spring open and insert the pawl from the inside out. It also makes it easier to work in an anticlockwise direction.
Once I discovered this technique I  became brave enough to take them all out and refit them individually. Just make sure you've got them the right way round
Sprag Clutch & Cleaning the Sprag clutch and bearing replacement. K1100_10
K75RTP - 1994
