Bonzo
Bonzo
For some time now I've been noticing my speedo mists up in the same place (bottom of left glass - above the fuel icon) and I've only just realized that this is due to a hairline fracture in the glass. I can only spot it in a certain light.
I'm pretty sure the glass is fixed into the plastic surround and not removable, so wondered if anyone had a spare surround they're not using in their vast collection of spares.
Don't know for sure if they're different, but mine's a 1990 16v.
Like I say, long shot - but worth an ask  cheers
1990 K100RS 4V (VIN# 6406682)
2017 R1200RS SE Sport
Cut your own from a piece of A4-sized 2mm or 3mm Lexan - you have the original for a pattern.
https://www.ebay.co.uk/itm/Polycarbonate-Clear-Plastic-Sheet-2mm-12mm-Lexan-Makrolon-Palsun-Polycasa/232639378785?hash=item362a633561:g:wiYAAOSwNDJaZg6w
Easy-peasy. Very Happy
Quite a few years ago I had some replacement glaases cut by the local plastic workshop. He cut one as left and right without the centre part the function section. He then cut a complete one with all the centre function symbols. I ended up just using the one half. It cost me $20.00 Au for the 3 pieces.
That was the easy part the next bit required cutting out the speedo glass. I used a high speed pneumatic pencil burr which I made a small adjustable router plate for. This allowed me to set the depth and angle of the cut so that I was only cutting the clear not the black surround. It was a very tedious job, too many revs and the plastic melted to the tool. The straight cut to separate it from the centre requires a fence so that you can run the tool across in a straight line. I free handed my first one. The second time around I learnt that WD40 can be used to stop the plastic sticking to the tool and a coarser toothed tool doesn't clog as much.
Once all the cuts were made the glass was held in by just a sliver of the remaining clear. This tapped out with a bit of tapping from the handle of a small hammer. The black surround  had to be cleaned up removing any remains of the clear. The replacement glass was sealed in with silicone free sealant. Any sealant, cleaner or protectant containing silicone will eventually causes the glass to develop crazing. Patience is needed when doing this job so I'd do a bit at a time, when I found myself starting to rush I stopped and leave it. I still have the router plate attachment that I made up which has done two replacement glasses.
Longshot. Anyone got a spare speedo glass/surround? Instru13
More pictures.
Longshot. Anyone got a spare speedo glass/surround? Instru10
Longshot. Anyone got a spare speedo glass/surround? Instru11
Longshot. Anyone got a spare speedo glass/surround? Instru12
gorio
I have found poly carbonate although tough as nails scratches easily. I prefer to use a cast acrylic for such things. I believe most windscreen and cast acrylic these days.
Hope you can turn out a new one.
1992 K100rs 16v
1997 R1100rt
2006 R1200rt
Past lives
Kawasaki Concours
1976 BMW R90s
1975 Ducati 860gt
1992 Honda VFR750
1985 Honda VF750
1982 Kawasaki 750GPZ
1975 Norton 850 Commando
Bonzo
Bonzo
Gulp! I struggle cutting an article out of the paper  Embarassed
Get a 5 year old to give you a hand. Or better still a teenager they know everything.
Bonzo
Bonzo
MartinW wrote:Get a 5 year old to give you a hand. Or better still a teenager they know everything.
Probably one-handed. They'll be holding their phone in the other.
moriarti
moriarti
Hi Bonzo,thinking outside the box and happy to be shotdown Laughing
Drill a small hole in the casing just under the glass and fit a pipe,
Range Rover/Jaguar do this in headlight units,If it doesn't work fill the hole up Idea
DadofHedgehog
DadofHedgehog
Bonzo wrote:For some time now I've been noticing my speedo mists up in the same place (bottom of left glass - above the fuel icon) and I've only just realized that this is due to a hairline fracture in the glass. I can only spot it in a certain light.
I've got a spare one.. PM me.
PRESENT:
1995 K75T.  I am the 3d owner.  Bought it in June 2019 with 6,242 miles on the odo.
1991 K100RS 4-valve attached to a 1990 Flexit sidecar. I am at least the 3d owner. Bought with 21,00+ miles on bike's odo.
PAST:
old (indeterminate age) Ural + sidecar
1997 Buell S3T Thunderbolt
1982 BMW R100CS
1974 Kawasaki KZ400
1970 Suzuki Titan
Longshot. Anyone got a spare speedo glass/surround? Ir-log10
 ;BMW; K1200RS Red
Suzi Q
Suzi Q
MartinW wrote:Quite a few years ago I had some replacement glaases cut by the local plastic workshop. He cut one as left and right without the centre part the function section. He then cut a complete one with all the centre function symbols. I ended up just using the one half. It cost me $20.00 Au for the 3 pieces.
Wow.
Got to say it again, WOW  Shocked
Bonzo
Bonzo
Nice spot Ringfad.
It would be nice, but with postage were talking £130. That would just burn  affraid Longshot. Anyone got a spare speedo glass/surround? 61740
14Back to top Go down   Longshot. Anyone got a spare speedo glass/surround? Empty Speedo glass Fri Aug 14, 2020 3:56 am
davemadsen
davemadsen
If you are still searching, I have an extra instrument panel for ‘87. Let me know if you still need it.
Dave
Bonzo
Bonzo
There's one on the way thank you Dave  Longshot. Anyone got a spare speedo glass/surround? 112350
