1Back to top Go down   Fuel Injector rebuild kits Empty Fuel Injector rebuild kits Sat Oct 17, 2020 10:28 pm
Mick67
Mick67
About to order a couple of sets of these.
https://www.aliexpress.com/i/32804772624.html
Was wondering if anybody else in Brisbane area was after some and I will add to order.
PM me if interested
Cheers Mick
K100RS 1984
VIN 0013414
2Back to top Go down   Fuel Injector rebuild kits Empty Re: Fuel Injector rebuild kits Sat Oct 17, 2020 10:38 pm
StandardK
StandardK
You branching out into injector rebuilds now Mick? Excellent, you’ll be the “go to” man for that from now on.
Regards
Dan
3Back to top Go down   Fuel Injector rebuild kits Empty Re: Fuel Injector rebuild kits Sat Oct 17, 2020 10:53 pm
Mick67
Mick67
Not me. Taking them to 'Moto by Martin'  up at North Lakes.
He has an ultrasonic cleaner and harness set-up. I picked up a spare set of injectors along with a relay box, relays and wiring loom off gumtree. So going to clean and refurb these and the ones in my bike.
K100RS 1984
VIN 0013414
4Back to top Go down   Fuel Injector rebuild kits Empty Re: Fuel Injector rebuild kits Sat Oct 17, 2020 11:09 pm
thats pretty cheap mick , good find !!!
5Back to top Go down   Fuel Injector rebuild kits Empty Re: Fuel Injector rebuild kits Sun Oct 18, 2020 12:21 am
US$1.89 with a $3.00 new user discount on orders over $4.00! They'll be paying me to buy them. I wonder how much the Uyghur
re-education camp member earns to put these kits together...
6Back to top Go down   Fuel Injector rebuild kits Empty Re: Fuel Injector rebuild kits Sun Oct 18, 2020 12:31 am
Put me down for three sets
Please mick
1986 K100 RS Motorsport
1988 K100 RS SE
1990 K1 known as Barn Find
#### K100 RS Project
7Back to top Go down   Fuel Injector rebuild kits Empty Re: Fuel Injector rebuild kits Sun Oct 18, 2020 1:21 am
Mick could please get a set of four for me I'll put them in stock. It will save me chasing them. By the way it's Wombat Works.
8Back to top Go down   Fuel Injector rebuild kits Empty Re: Fuel Injector rebuild kits Sun Oct 18, 2020 6:15 am
Mick67
Mick67
So a bit of maths
Me 2
Martin 1
Matt 3
= 8 sets ordered ... I see numerals as being adjectival not absolutes.Very Happy
A$35 ( got hit with GST) delivered by Nov 16. So $4.50ish a set delivered. Will let you know when/if they arrive.
K100RS 1984
VIN 0013414
9Back to top Go down   Fuel Injector rebuild kits Empty Re: Fuel Injector rebuild kits Sun Oct 18, 2020 8:38 am
I buy the set for the E32 V12 BMW sedan and get 3 sets for a K100
11Back to top Go down   Fuel Injector rebuild kits Empty Re: Fuel Injector rebuild kits Sun Oct 18, 2020 11:09 pm
brickrider2
brickrider2
Two Wheels Better wrote:US$1.89 with a $3.00 new user discount on orders over $4.00! They'll be paying me to buy them. I wonder how much the Uyghur
Ugh, that's some dark humor if ever there was....
1996 K1100LT
12Back to top Go down   Fuel Injector rebuild kits Empty Re: Fuel Injector rebuild kits Mon Oct 19, 2020 5:24 am
nino
Hello Jbt, do you still have that 30 USD injectors on your K 100 engine? How it behaves, can you tell something more, for example about cold start, consumption, high revs?
Thanks in advance
13Back to top Go down   Fuel Injector rebuild kits Empty Re: Fuel Injector rebuild kits Mon Oct 19, 2020 8:03 am
nino wrote:Hello Jbt, do you still have that 30 USD injectors on your K 100 engine? How it behaves, can you tell something more, for example about cold start, consumption, high revs?
Thanks in advance
Yes, I still do have them.
I can't tell if they improved anything, as I mounted these injectors on a K100 I bought damaged, and never rode it before.
But comparing to other K100 I own, it works much better. No cold start issue, no trouble reving, and a funny push at high revs. Nothing to compare to my other '85 k100 that seems empty and weak in comparison.
I've rode it about 500 km since the rebuild.
These injectors seem to be richer than the usual ones, with a larger debit.
All the fuel injection line is new, and the fuel pressure regulator is a bit tuned, it may also explain.
The only surprise is about the O ring looking more sticky than gummy, as slime.
I did not trust them, I don't like playing with fuel leaks, I changed them for OEM O rings.
14Back to top Go down   Fuel Injector rebuild kits Empty Re: Fuel Injector rebuild kits Mon Oct 19, 2020 3:40 pm
nino
Thanks for sharing infos. One more question. Did you measure consumption? Higher or same as original injectors? How did you tune fuel pressure regulator. Higher pressure?
15Back to top Go down   Fuel Injector rebuild kits Empty Re: Fuel Injector rebuild kits Mon Oct 19, 2020 4:15 pm
I did not measure fuel consumption. This bike runs too rarely to bother about.
To enhance fuel pressure, the good old trick is to smash the bottom of the regulator. It preloads the internal spring, and the regulator opens at higher pressure.
But you also can change it for an adjustable presssure regulator.
16Back to top Go down   Fuel Injector rebuild kits Empty Re: Fuel Injector rebuild kits Tue Oct 20, 2020 2:27 am
nino
I have adjustable fuel pressure regulator installed and adjusted on 3,2 bar instead 2,5. with old injectors. I tried with some chinese injectors Shunzi Liron(?) and it worked only on 0,5 bars with that adjustable FPR. To much fuel probably with standard pressure.
So I removed chinese and put old Bosch injectors.
17Back to top Go down   Fuel Injector rebuild kits Empty Re: Fuel Injector rebuild kits Tue Oct 20, 2020 3:11 am
3.2 is way too much IMHO.
2,8 is the max you can set without internal modifications (big bore, long opening camshaft, etc;)
