1Back to top Go down   K75S 1988 Oil in coolant. Empty K75S 1988 Oil in coolant. Thu Mar 17, 2011 11:27 am
BooG
BooG
Hi. I seem to have emulsified oil in the cooland expansion tank. I opened the filler cap and there was a brown gunk also. Is this problem at the water pump? Is it just a case of re-building it?
Thanks.
2Back to top Go down   K75S 1988 Oil in coolant. Empty K75S 1988 Oil in coolant. Thu Mar 17, 2011 3:26 pm
Dennis
Dennis
The oil and water pumps are actually separate, though both live in the same housing. There is a tell-tale hole in the pump case, facing downwards, and, unfortunately, many times we have heard of the hole being blocked solid with crud. This then can cause the weeping oil to be pushed into the cooling side as the mechanical seal on the water pump only resists leakage in 1 direction (from the inside towards the outside). The oil will always be pushed into the coolant as the pressure is higher. So yes, it may be that this is the reason for oil in the water, though it is not the only way it can get there. Look for the hole and clean it out with a drill bit, there are pics on the forum of this. Then, if oil weeps from the hole, a pump rebuild will be necessary.
3Back to top Go down   K75S 1988 Oil in coolant. Empty Re: K75S 1988 Oil in coolant. Thu Mar 17, 2011 5:06 pm
There's heaps of info on this problem, even recently, posted here. Do a search in the 'engine' section and you will find the long and the short of it. Be certain to not ride this motorbike until the issue is rectified. Oil and coolant do not mix well round the engine's plain bearings, at all.
Welcome to the forum, an auspicious start!
