I see this on a lot of the kustom Ks.
Example:
https://www.ebay.com/itm/164133573799?ul_noapp=true
2Back to top Go down   Why do the strippers put the exhaust can on the right side? Empty Looks cool Sat Mar 21, 2020 4:28 pm
stanthomas
stanthomas
It shows off the single-sided wheel, a la RC30.
I think Honda messed-up with the VFR750F by putting the exhaust on the other side. There are practical reasons for both orientations. Exhaust on the swing-arm side means you can get  the wheel off quickly, important on an RC30 but perhaps no so much for a bike with panier mounts. Exhaust on the other side is easier to route, leaves room for a centre stand and makes the bike look more 'balanced'.
K100RS 16V '91
GF Wollongong
GF Wollongong
I think someone's put a lot of thought, time, effort and money into it. Good luck to them.
However, the front brake MC sitting so high detracts from the shape and lines of the bike.
GF
Suzi Q
Suzi Q
Pulls up alongside car at traffic lights;  "Hey buddy, whaddya think of ma cool mosheen?"
Car Driver; "S'up to temperature mate, would you like me to knock the fast idle off?"
Nice work though. Nice touches - like the colour-coded horn.
"All the electricity was made again, cooperating with Motogadget m.unit blue."
But, somehow I still twigged to what he is trying to say.
"Politics is the entertainment division of the military industrial complex."
- Frank Zappa
This K100 Too!
- Frank Zappa
stanthomas wrote:Exhaust on the swing-arm side means you can get  the wheel off quickly.
Most of the ones I've seen ditch the center stand in order to route the exhaust behind the tranny. Good luck getting the wheel off easily without a center stand.
cycleman
cycleman
Both of those bike links, show some sweet work.  A good way to go if you are into that stuff and have a less than stellar RT/LT.
GF Wollongong wrote:I think someone's put a lot of thought, time, effort and money into it. Good luck to them.
GF
Agreed, but that's the way they are on current sportsbikes where it's hidden behind a windscreen. I would have kept it lower profile.
- Frank Zappa
stanthomas
stanthomas
You need one of these:
Why do the strippers put the exhaust can on the right side? Honda-Rc30-Genuine-Paddock-Stand-Vfr750R-Hrc
Which is, of course, entirely impractical to carry around. And useless on a K 'cos there's no hole thru the wheel centre (looks like it might be possible on the R Nine T although they still put the exhaust on the 'conservative' side).
On a more general point, why do these stripped bikes command such high prices? Taking off the standard parts to make a street fighter was what you did after smashing the bike up and not being able to afford to put it right. When we made Tritons, we put the best engine in the best chassis to make a better, more purposeful bike. Yes, it was 'cos there were lots of crashed Bonnevilles and lots of Featherbed chassis discarded by the Cooper racecar builders, but it was a different bike. K (and boxer) customs are just standard bikes minus stuff.
Some, like the one here, show a bit of care and attention but it's still very much a standard K with holes in the gas tank to clip the fairing into. A custom is very much an expression of your own personal taste, are there really that many people ready to stump up good money for someone else's idea of what to do with a bike rescued from the breakers yard? Surely a tidy original is always worth more, after all it cost a lot to keep it looking good and running right?
K100RS 16V '91
My version of a café racer, but more practical, it had a rack and saddle bags and I used to be able to ride it to the shops, and it got plenty of attention. It was more individual and unique than most café racers and all I destroyed in making it was a Chinese bicycle. The motor was from an old rotary hoe that I didn't even see and it was about to go to the tip. cheers
Why do the strippers put the exhaust can on the right side? Le_fau14
12Back to top Go down   Why do the strippers put the exhaust can on the right side? Empty Muffler Sun Mar 22, 2020 8:09 pm
daveyson
daveyson
I rode cruisers before a brick. With bikes,  and cruisers in particular, it is very odd to have a muffler on the left side, unless there's one on both sides. Almost as odd as a brake lever on the left side.
I'm used to it now. Probably even better, since most drops are on the right side, so no damage to the muffler then.
(agree you get a better view of the non standard wheel, and resisting the urge to say so you can go around left hand corners faster)
 ~120,000 km
Suzi Q
Suzi Q
Oooh, I like that.
I think I've just felt a twitch about the next project.
Thanks Chris the other side showing clutch. Top speed on the flat 40 Kph.
Why do the strippers put the exhaust can on the right side? Le_fau15
teuski
teuski
Some strippers do weird things with their "exhausts" Very Happy
Open rear wheel looks really neat. For my K i found an old Nico Bakker dual exhaust, nice sounds and much shorter than the original trumpet.
moriarti
moriarti
Amen to that Bro
Stumpy
Stumpy
I am rewiring my bike, I thought about changing the switches and everything. I have decided to keep the original switches and keep the bike as standard as possible, I am just replacing the fuses and relays with an M-Unit and replacing the old warn out wiring. I think that the K is good bike it just needs to be updated in the electrical department. I might change the dashboard but the exhaust will remain. I think people change the look of the bike and spoil a good looking bike.
BMW K100RT 0095857
To answer the original question: because they can? (Think about it).
Because they are all "individuals"
