1 How to ride home when your fuel pump fails Sun Aug 04, 2019 5:06 am
daveyson
If your fuel pump fails, you're in an isolated area and you don't have a spare, simply connect a wire from the yellow - grey wire (earth to injectors) to the battery negative post, and you can ride home.
This provides constantly open injectors, which with the help of gravity fed fuel and vacuum from the pistons, is enough, but not ideal, to ride home. It is sometimes a little on the rich side which can be overcome by backing off the throttle.
I have proved this today with a one and a half hour ride (45 minutes each way) reaching speeds of 100 kmh (60 mph)
This was with a 2v brick. The pump is working, so I simulated a failed pump by disconnecting the fuel pump electrical plug.
It helps to keep the revs high.
If the pump were to suddenly start working again, that would result in a stall because of the constantly open injectors, so unplugging the fuel pump plug would be best with this temporary modification.
Last edited by daveyson on Sat Feb 29, 2020 2:48 am; edited 8 times in total (Reason for editing : Edit for photo.)
11/1985 BMW K100RT (late model) Vin. 0090567
~120,000 km
