1 Brake light on all time Fri Jan 31, 2020 5:06 am
Packo
I really struggle with electrics !!!
My brake light comes on with the ignition and stays on all the time until the ignition is switched off.
The RED warning light on the cluster operates as it should ie. OFF once each of the brake switches are operated
With ignition ON I have power to both wires at the rear brake switch all the time so that appears to be the problem.
What are the steps to try to track down the "short" ??
I have checked the earth wires under the tank and as they are bundled together and all other functions on the bike are normal I don't see how it would be there.
From here do I go to the BMU and if so what do I check and how
______________
83 K100 HRD Outfit
1992 K1100 Outfit
2003 R1150 GSA Outfit
1983 K100 Basic
