1 K1100LT Brake Hose Thu Jan 09, 2020 7:26 pm
brickrider2
I've been told that it's possible to pull the wiring away from the frame tube to access the point where the rubber hose from the master cylinder joins the steel tube that runs to the ABS pump. I haven't been able to do that -- not even close. I cut the plastic ties and pulled all the wiring harness away from the frame that I could, but I can hardly see the connection point, much less access it with a wrench. My questions are: has anyone here actually replaced that hose? How? Must one remove the radiator and gain access from below the headstock? TIA
1996 K1100LT
