1Back to top Go down   tick over  Empty tick over Sun Oct 17, 2010 4:03 pm
Rob Roy Mcgregor
high should i have a slight hesitation during tick over like one cylinder was not quite firing every so often. . or should it be constantly smooth . . Question
2Back to top Go down   tick over  Empty Re: tick over Mon Oct 18, 2010 3:09 am
Depends on the revs at tick over if you are idling at below 900 it may seem a bit lumpy, a check would be to see with neon spark plug testers if the miss corresponds with a missed flash. Does the bike ever miss when it is running at constant revs on the road?
3Back to top Go down   tick over  Empty Re: tick over Mon Oct 18, 2010 9:10 am
Rob Roy Mcgregor
Only on tick over ..probably normal im thinking ,runs smooth enough through the rest of the rev range thanks k.
4Back to top Go down   tick over  Empty Re: tick over Thu Oct 21, 2010 9:16 am
battyone
I've been thru a few different motors lol and none of them idle perfectly smoothly,there always seem to be the odd hiccup.
The fuelling is very lean at tickover on most K's...although I have seen variations with different FI controllers and airflow meters.
Try adjusting the idle air bypass screw on the airflow meter.Turning in will richen the mixture a touch,which should help smooth the idle.
K's are set at stoichiometric air fuel ratio.. at idle 14.7:1....If I were tuning a carburettor bike I would set it as rich as the bike wanted.My (hinkley)bonneville is 12:1 at idle,
5Back to top Go down   tick over  Empty Re: tick over Thu Oct 21, 2010 9:49 am
Rob Roy Mcgregor
Nice one i will give it a go . . was also wondering maybe uleaded has an affect on it , mines a lead head unleaded being a lower octain . . ive got addative in it . . may be it doesnt make any difference in the lower rev range . . Smile
6Back to top Go down   tick over  Empty Re: tick over Thu Oct 21, 2010 4:18 pm
battyone
Mine never last long enough to worry about lead replacement additives.Whoops!
However,I'm never going to run on shell Vpower again and I am going to look at additives,preferably ones with lubricating qualities.
When we first got unleaded petrols there was definitely a difference at tickover,I always found my bikes idled at higher rpm on unleaded than good 'ol 4star.
7Back to top Go down   tick over  Empty Re: tick over Thu Oct 21, 2010 5:09 pm
Rob Roy Mcgregor
:cyclops: suppose the lead was making the fuel thicker Wink
8Back to top Go down   tick over  Empty Re: tick over Thu Oct 21, 2010 5:29 pm
battyone
Nah heavier Laughing
9Back to top Go down   tick over  Empty Re: tick over Thu Oct 21, 2010 5:33 pm
Rob Roy Mcgregor
the bike is heavy enough without the extra lead weight drunken
