1 [solved]Eastern Beaver fuse panel relay Sat Dec 07, 2019 4:34 pm
tinyspuds
Hi,
Installed my H4 relays and loom and very impressed so thanks to many for the rec. I’ve had to direct connect to the battery for now as I am unable to get the PC8 fuse panel to work, I have 12 volts up to the fuse but the relay stays silent on either battery connect or when powered through the switched line (which I have connected to the starter relay terminal). I’ve swapped in the horn relay and this can be heard to activate on battery connect, but otherwise doesn’t allow the fuse box to work.
I’m assuming therefore a relay fault, but can’t source one in Europe or identify a substitute.
I’m in contact with EB this weekend, but with postage times from Japan I thought I would try locally.
Does anyone know an EU source for the panasonic CB1ATM12V or equivalent?
Cheers, Stu
Cheers, Stu
