The Chad
Hi. So I thought I had a fueling problem since my bike was cutting out after warming up a bit, and using a hair drier to heat the Hall sensor didn't affect the bike in deciding when it would shut off. But today, after disassembling all the electrical connections again to test them, I found that I had no continuity between Pin 2,3 and 4 from the Ignition Plug on the female side. (And no power from pin 2). I checked the wire for any cuts, but there is none. Can the male plug to the hall sensor go bad? It looks to be in good shape. What should I test next?
