club_c
club_c
Hey all, I've searched the site but haven't found an answer to my question. I am pulling off the timing chain cover to polish it up. I have read the Hall Sensor needs to be removed from the cover to get the cover off. I haven't taken off the Hall Sensor yet. What I'm wondering is, does the Hall Sensor just bolt back up, or do I need to set it in a certain manner, sort of like the TPS?
robinm
robinm
Yes, defiantly adjustable, mark it's position with a fine scribe or similar, the finer the mark the better as it is a small diameter unit and a wide mark can easily result in a 1 or 2 degree difference when put back together.
ReneZ
ReneZ
Get yourself a manual mate, this is not a job you want to do without. It comes quite precise and can have big effects on the engine running.
Rene
BMW K100 - 1985 (0030029) Scotland Is there an adjustment for the Hall Sensor? Rain
club_c
club_c
Yes, have one thanks. I posted while at work, no manual available, and I had time to consider the chore.
I previously removed the Hall sensors and re-adjusted them on the mark that I scribed before removal.
Later I checked the timing with a professional timing light and it was dead on the spot.
The best way to mark them is to scribe 2 Vs in opposite direction ( ><) in stead of 2 straight lines (- -).
If your scribing is precise, you may get a maximum of 1/2 of a degree error when re-installing.
I wouldn't worry about such an error (if you have it).
Bert
Is there an adjustment for the Hall Sensor? Frog15Is there an adjustment for the Hall Sensor? Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
