1Back to top Go down   odometer set screw gap? Empty odometer set screw gap? Sat Nov 16, 2019 2:43 am
schrocketeer
schrocketeer
Would you please help me with the gap for the set screw that presses up against the shaft that holds the odometer gears? It's the white nylon screw that touches up against the the steel shaft with the odometer's gears. In the attached picture there is a red circle around the area.
In my last adventure going in this deep, I didn't pay attention to the gap. When my odometer hit 61,999 miles, it got stuck and would not roll over. This also kept the trip meter from functioning.
Before I put it back together, I'd like to go on more than a guess for the gap.
Thanks. odometer set screw gap? K100_o10
Ken
85 K100RT
91 XR250
97 XR100
70 CT70
06 YFM400
Past Bikes:
95 VLX600
86 TRX250
02 GZ250
83 Z50R
78 ATC90
86 XR250
79 XR500
72 AT1
75 YZ360
78 DT400
75 DT125
73 Trail 70
Dad's bikes I rode in high school
69 CL175K3 Scrambler
71 R5-B (RD350 predecessor)
2Back to top Go down   odometer set screw gap? Empty Re: odometer set screw gap? Tue Nov 19, 2019 10:14 pm
schrocketeer
schrocketeer
Ricardo Palao helped me, suggesting a gap of 2mm, on the FaceBook group "BMW-K  motorcycles K1 k75  k100  k1100 (purists)". I've put around 250 miles on it since reassembling with that tolerance, and it's working great.
Ken
85 K100RT
91 XR250
97 XR100
70 CT70
06 YFM400
Past Bikes:
95 VLX600
86 TRX250
02 GZ250
83 Z50R
78 ATC90
86 XR250
79 XR500
72 AT1
75 YZ360
78 DT400
75 DT125
73 Trail 70
3Back to top Go down   odometer set screw gap? Empty Re: odometer set screw gap? Wed Nov 20, 2019 7:18 am
Having had a look at a couple of mine, my guess is that the screw is only there on the very early speedos where it's possible to remove the spindle - it prevents the spindle from migrating across and dropping the drums. On the later speedos the other (non-screw) end of the spindle is crushed to prevent it from being pulled out. I haven't seen that screw in the later speedos.
Disclaimer: I've only dismantled around six speedos in total and those were my findings.
