1Back to top Go down   swinging arm bearing inspection Empty swinging arm bearing inspection Fri Nov 01, 2019 11:48 am
tinyspuds
tinyspuds
Having searched here, Clymer and YT, and being well past the age of embarrassment:
Before removing my swing arm I did the standard lateral movement test and it was rock solid.
However now I have the arm out I thought I’d do a visual check. I replaced the pivots and both bearings rock freely in their seats (couldn’t upload the mp4 but I do mean freely and you can hear them rattle).
I am running a biggish chair and just had to replace the front wheel bearings.
To my mind there is no question that they are shot to pieces, but they are so comically bad and show no movement with the arm in place I just wonder if I’m missing some intentional design feature.
So, simple question(s)
Should they rock in their seats?
The adjustable pivot had been PreviOusly red loctited in and I wonder if it might just have been torqued down so hard that it hid the in situ symptom. Possible?
Cheers all, Stu
2Back to top Go down   swinging arm bearing inspection Empty Re: swinging arm bearing inspection Fri Nov 01, 2019 12:27 pm
likely the last person in there  forgot to grease them ?   and is a totally useless mechanic
3Back to top Go down   swinging arm bearing inspection Empty Re: swinging arm bearing inspection Fri Nov 01, 2019 12:32 pm
tinyspuds
tinyspuds
charlie99 wrote:likely the last person in there  forgot to grease them ?   and is a totally useless mechanic
Not even close to the language I’ve been using Charlie  Evil or Very Mad .
So you agree: if they rock, they’re cock?
4Back to top Go down   swinging arm bearing inspection Empty Re: swinging arm bearing inspection Fri Nov 01, 2019 7:15 pm
they are a bevel roller bearing , so should move around a bit dry , its not until they are tightened that they mate home properly
to grease them , there should be a cup of alloy behind the bearing in the swing arm , place the right grease inside the centre core and use the pivot pin to pressure the grease home deep into the roller bearing , it should start working its way towards the front so that a little excess bleeds through the front cage - seal area when full .
hope that helps
5Back to top Go down   swinging arm bearing inspection Empty Re: swinging arm bearing inspection Sat Nov 02, 2019 4:21 am
tinyspuds
tinyspuds
Thanks Charlie, I’ll grease them up and put them back. Lots of copperslip on the pivots and no loctite should make any future replacement pretty straightforward compared to this time.
Now onwards to the clutch.
6Back to top Go down   swinging arm bearing inspection Empty Re: swinging arm bearing inspection Sun Nov 03, 2019 5:25 am
swinging arm bearing inspection 112350
7Back to top Go down   swinging arm bearing inspection Empty Re: swinging arm bearing inspection Sun Nov 03, 2019 7:29 am
