1Back to top Go down   High idle Empty High idle Sat Oct 26, 2019 9:21 pm
futech
futech
So I finally got my build to run, but found my idle was pretty high. Initially it started idling around 3k then when I revved a bit it stuck around 4-5k. I ended up lowering the idle adjuster pretty much until the bolt no longer touched the stop. It’s currently idling around 1.5-2k.
Would this be a TPS issue or choke cable issue, or potentially something else?
2Back to top Go down   High idle Empty Re: High idle Sun Oct 27, 2019 10:48 am
Woodie
Woodie
Have a look at the position of the ratchet clamps on the rubber inlet manifolds.  I had a similar issue and it turned out that one of the clamps was turned in just enough to prevent the linkage from dropping all the way down.
High idle Logo2111
1985 K100RT  52667
1990 K75RT 6018570 (project)
3Back to top Go down   High idle Empty Re: High idle Sun Oct 27, 2019 11:51 am
The TPS can hold the throttle open if not adjusted properly.
