1 High idle Sun Oct 27, 2019 1:21 am
futech
So I finally got my build to run, but found my idle was pretty high. Initially it started idling around 3k then when I revved a bit it stuck around 4-5k. I ended up lowering the idle adjuster pretty much until the bolt no longer touched the stop. It’s currently idling around 1.5-2k.
Would this be a TPS issue or choke cable issue, or potentially something else?
