SniperX
SniperX
After completely draining the tank, how to I evacuate the fuel system along with the injection?
1985 BMW K100RT, 2006 Ducati ST3, 1996 Honda CBR1000f, 2001 Honda XR400r
If I found myself in this predicament after draining the tank, might blow through the fuel rail with compressed air then put enough fresh fuel in the tank to determine if the engine would start up and clean the rail and injectors using detergents already in the gasoline, or disconnect the fuel rail with the injectors attached, disconnect the injectors from the rail then clean the rail and send the injectors out for reconditioning.
I'd have needed to convince myself that significant water infiltration was occurring before doing any of this though. Smile How did you do that?
Run some ethanol fuel through gets rid of water in no time flat. Then run a couple of tanks of regular fuel to get rid of the ethanol.
4Back to top Go down   I may have water in my gas and tank... Empty Fuel tank Fri Nov 01, 2019 8:03 am
daveyson
daveyson
 ~120,000 km
