1Back to top Go down   Hello from Aylesbury Empty Hello from Aylesbury Mon Sep 23, 2019 8:01 pm
SteveWilson
SteveWilson
Hi - New to this forum - Not so to the world in general :-) I'm running a pretty much stock Black 1993 K75S with a stack of bits to add - maybe this winter! Changes at the moment limited to a wider 3 spoke rear wheel with radial tyre. Recovered K1100 seat, K1100 topbox - Oh and a pair of hand guards
Planned - Matching front wheel with bigger discs and repositioned calipers
Maybe replacement blue spot calipers later
High output alternator
Cibie headlamp
Right hand exhaust
K100 diff
Junking the ABS
Later -
Respray Martini stripes over Porsche silver
Aftermarket ECU
Etc Etc
Its not all about me - but this bit is
Casual biker but repeat offender pretty much always had a bike since about age 14 (NSU Quickly)
Pretty much always been an engineer of some description (currently system safety)
Pretty much always messed about with them - stock is just the starting point:-)
Other runner is a 1971 BSA A65 with a modern disc brake front end.
Almost half way to having all the tools I need.
Steve
2Back to top Go down   Hello from Aylesbury Empty Re: Hello from Aylesbury Tue Sep 24, 2019 3:04 am
Welcome Steve Smile
Pics, or it didn't happen Razz
Hello from Aylesbury Eu-log10  K1100RS/LT - R1200RT - R1100RS - Cagiva SST 350 Ala Verde - K75LT project - K75 Schurgers - K75S - K1100RS - K75RT - K75C
3Back to top Go down   Hello from Aylesbury Empty Re: Hello from Aylesbury Wed Oct 02, 2019 1:17 pm
Welcome to the forum. Don't be afraid to ask questions....
Am a regular visitor your way as my daughter lives at long Marston.....
4Back to top Go down   Hello from Aylesbury Empty Hi Wed Oct 02, 2019 2:34 pm
Noisey
Noisey
Hi steve Wilson.. Aylesbury , nice area, just a shame it would mean the A40 for me !! ha ha, we use to visit friends regularly in Dunstable and pass thro' Aylesbury on a whole multitude of bikes and cars, typically at enthusiastic speeds.. ahem...
I'm a newbie too, hoping to hang around bmw's a bit longer...
Hi Olaf, Long Marston, just up the road from us, tip of the cotswolds, lovely area and lovely pubs, which I am sure you have already found out !!...
Noisey
5Back to top Go down   Hello from Aylesbury Empty Re: Hello from Aylesbury Wed Oct 02, 2019 3:44 pm
If you want better brakes on the front then I recommend swapping in a complete K100RS4V, K1 or K1100 front end.  It's a lot of parts but in addition to better brakes you get much better forks.
I've done it to several K75s.
6Back to top Go down   Hello from Aylesbury Empty Re: Hello from Aylesbury Wed Oct 02, 2019 7:26 pm
Something else that seems to work, but I'm not entirely sure why. Change the hydraulic lines so that you have two lines that run directly from the m/c to each caliper. I suspect that the ex-factory setup is form over function and can be a bitch to bleed cleanly.
7Back to top Go down   Hello from Aylesbury Empty Re: Hello from Aylesbury Wed Oct 02, 2019 8:25 pm
Here;s what I do to make the brakes better on K75s and K100s:
http://www.kbikeparts.com/classickbikes.com/ckb.tech/0.ckb.tech.files/2vbrakes/2vbrakes.htm
8Back to top Go down   Hello from Aylesbury Empty Re: Hello from Aylesbury Thu Oct 03, 2019 1:38 am
NoSprk
NoSprk
Welcome
'93 K1100LT '91 R100GSPD '73 R75/5
9Back to top Go down   Hello from Aylesbury Empty Re: Hello from Aylesbury Fri Oct 04, 2019 8:52 am
td5
td5
HI from down under Steve,
I replaced all my lines with Stainless from motobins, made a noticeable difference, still 30 year old tech but liveable.
Mike
Hello from Aylesbury K_engi10
1988 / K100RS
2013 / R1200GS
2015 / K1300R
2002 / R1100S BCR
