Bob go out and buy a set of shoe lifts, that will give you anywhere from 1/2" to 1" plus. Then go out and buy yourself a new pair of motorcycle boots with the thickest soles you can find take a tape measure. Try the lifts in the boots before you buy them. that will give you another 1" plus.
Shop around for a GOOD motorcycle seat man all are not created equal. A good motorcycle seat upholsterer can do the following to help 1/ Shave the nose of your seat allowing your legs to move in reducing the distance required to ground. 2/ Lower and repad your seat without effecting comfort.
You can lower the front forks through the triple trees buy up 1/2" without greatly effecting the handling, and still be able to get it onto the centre stand. Lowering the rear shock as well by 3/4" can be done but you will effect handling clearance and will probably have to modify your centre stand.
Last edited by MartinW on Wed Oct 02, 2019 3:29 pm; edited 1 time in total (Reason for editing : Fix font size.)
