Number of posts : 7969
No.....because I found a Randolph tank in US, which incidentally is still there with Ronald Scibetti on FB. It was $750 which was reasonable enough as it takes all the standard K bike pump etc etc inside the tank. problem for me was $250 upwards for shipping cost then add tax 11% and VAT 23% on the lost and then painting at this end.....so it stalled a little.
Then I bought a K1100LT tank for the same money.....but it came with the complete K1100LT attached and is more economical. I just did one of those round trips on it last Monday.
If you box clever under the seat and remove the battery and the other gubbins under the seat just get a block of polystyrene and patiently saw it way until it will fit. You will need to mount it on rubber but that can be done on the battery tray and if you box really clever you could use the original battery clamp screw holes for mounting. You will need to resolve the coolant expansion bottle but as race guys will tell you, it can go anywhere. Having an RS to work with I can tell you its possible to locate it up front inside the fairing. Its not heavy. By making the top of the tank removable you make it easy to avoid removing the tank for routine servicing. A nice side effect is that if you run the fuel down removing the original tank for maintenance is a cinch.
My calculations suggested you would get 7 litres extra by doing this. However I think the usable extra would be higher as most of us only see about 18 litres max out of the original tanks 21-22 litre capacity.
1971 Yamaha 125 YAS-1
