1Back to top Go down   Clutch Cable Empty Clutch Cable Mon Sep 09, 2019 2:19 pm
tjh1985
tjh1985
My clutch cabke broke on my new (to me) k100 - need some input from the crew here;
1) Best/Lowest Price to buy a new clutch cable gor my ‘85 k100rs?
2) What kind of lube should i use on either end of the cable?
3) Any recomendations on a good video to show me how to do this right?
Aporeciate you all!
Thomas
http://www.thomashurst.com
2Back to top Go down   Clutch Cable Empty Re: Clutch Cable Mon Sep 09, 2019 2:21 pm
Davep
Davep
Motorworks - £12. And I use lithium grease, about £3 a tube which has lasted over a couple of years so far.
Dave
Clutch Cable Eu-log10BMW K100RS 1983 (Main ride)
                      Suzuki GSX 750 ET 1979 (Needs work)
                      Kawasaki Zephyr 750 1992 (Needs hiding)
3Back to top Go down   Clutch Cable Empty Re: Clutch Cable Mon Sep 09, 2019 3:32 pm
Which end did it break at?
The easiest way to thread the new clutch cable is to pull it through with the old one.  I usually tie a long piece of wire to the old cable, pull that through and then use the wire to pull the new cable though.  (Or a piece of strong string.) A little wiggling and pulling back and forth while doing this usually helps.
Here's the BMW instructions on how to adjust the clutch cable:
Clutch Cable K_Bike_Clutch_Adjust
And as I showed you during the spline lube try to keep the clutch arm from traveling too far out in order to keep the $48 clutch boot from tearing.
4Back to top Go down   Clutch Cable Empty Re: Clutch Cable Mon Sep 09, 2019 5:50 pm
tjh1985
tjh1985
Duck it broke at the hand lever
5Back to top Go down   Clutch Cable Empty Re: Clutch Cable Mon Sep 09, 2019 5:52 pm
Got a pic of how it's attached to your aftermarket controls?
6Back to top Go down   Clutch Cable Empty Re: Clutch Cable Mon Sep 09, 2019 5:54 pm
tjh1985
tjh1985
No, but I’ll get one when I get off work tonight
