1Back to top Go down   Hello from Glasgow Empty Hello from Glasgow Thu Aug 29, 2019 8:38 pm
MichalPe
MichalPe
Hello Guys.
My name is Michal and I live in Glasgow UK. I've just bought 1984 RS which spend last 6 or 7 years in the garage. I ordered the new battery today and will try to start it as soon as its delivered. I did some reading of this forum and I am finding it very useful. A lot of great people with big knowledge.
2Back to top Go down   Hello from Glasgow Empty Re: Hello from Glasgow Thu Aug 29, 2019 8:55 pm
moriarti
moriarti
A warm welKome to you,just a tip if engine spins but wont start,put some oil down sparkplug holes
Have fun  Hello from Glasgow 44271
3Back to top Go down   Hello from Glasgow Empty Re: Hello from Glasgow Thu Aug 29, 2019 9:58 pm
mike d
Welcome to the forum,
Before you start it, have a look at the state of the rubber parts in the fuel tank.
If they are turning to mush, then trying to start the bike will just push al the crud through to the injectors.
Swill the tank out and have a good look.
Mike
4Back to top Go down   Hello from Glasgow Empty It's alive :) Mon Sep 02, 2019 5:53 pm
MichalPe
MichalPe
So I had some time yesterday and I've got new battery on Friday. The bike spend 6-7 years in garage before I've got it . The chap I bought it from had dropped it (minor crack on faring), he started to taking it apart for repair but lost interest due to some other stuff. I put a new oil and filter, fuel filter (checked all fuel lines as you guys advised), installed 4 new spark plugs and it started after like 3rd crank Smile. So now a lot of cleaning, fairing repair and maybe respray. Mine is silverish green (awful color) and I really dig the white ones with black engine (motorsport style Smile.
5Back to top Go down   Hello from Glasgow Empty Re: Hello from Glasgow Mon Sep 02, 2019 6:41 pm
Welcome Michal Smile
Hello from Glasgow Eu-log10  K1100RS/LT - R1200RT - R1100RS - Cagiva SST 350 Ala Verde - K75LT project - K75 Schurgers - K75S - K1100RS - K75RT - K75C
6Back to top Go down   Hello from Glasgow Empty Re: Hello from Glasgow Tue Sep 03, 2019 3:21 am
Welcome!  I also like the white with black running gear.  Hello from Glasgow Bikes_12
7Back to top Go down   Hello from Glasgow Empty Re: Hello from Glasgow Tue Sep 03, 2019 11:37 pm
I have a red K1100RS awaiting restoration. Love the White!!
Hello from Glasgow 177912
Hello from Glasgow Ir-log1188....May contain nuts!Hello from Glasgow Ir-log11
K75RTP - 1994
8Back to top Go down   Hello from Glasgow Empty Re: Hello from Glasgow Thu Sep 05, 2019 2:43 pm
mibh
mibh
welcome!
9Back to top Go down   Hello from Glasgow Empty Re: Hello from Glasgow Thu Sep 05, 2019 10:46 pm
td5
td5
Welcome from a fellow Scot from down under. Just ask tons of help here.
Mike
Hello from Glasgow K_engi10
1988 / K100RS
2013 / R1200GS
2015 / K1300R
2002 / R1100S BCR
10Back to top Go down   Hello from Glasgow Empty Re: Hello from Glasgow Thu Sep 05, 2019 11:38 pm
Stumpy
Stumpy
Welcome to the forum, while waiting, wash the tank out and check the internal parts, if the oil level is correct in the crankcase, leave the bike on its side stand. the oil should seep into the head and lube the barrels. this is what makes the K bikes smoke on startup.
BMW K100RT 0095857
11Back to top Go down   Hello from Glasgow Empty Re: Hello from Glasgow Fri Sep 06, 2019 1:11 am
moriarti wrote:A warm welKome to you,just a tip if engine spins but wont start,put some oil down sparkplug holes
What's the point of this?
When I start a K that hasn't run in several years I usually spray some fogging oil into the cylinders and then run the starter with the L-Jetronic disconnected for several spins.  It may not be necessary but I do it so the cylinders/rings have some lubrication on the initial start before the oil gets circulating.
12Back to top Go down   Hello from Glasgow Empty Re: Hello from Glasgow Fri Sep 06, 2019 1:12 am
MichalPe: WelKome!
http://bit.ly/new2kbikes
13Back to top Go down   Hello from Glasgow Empty Re: Hello from Glasgow Wed Sep 11, 2019 12:09 am
playlikewedream
playlikewedream
Hello from Glasgow 212902 Hello from Glasgow 177912
Hello from Glasgow Ir-log10Hello from Glasgow Ir-log10
;BMW; K1 1990 Laguna Blue and Yellow ;BMW;
;BMW; K1100RS 1997 Sedien Blue.;BMW;
Its not about the journey or the destination, it's about the friends you make on the way.
