Number of posts : 7969
While the frames are broadly similar the engine mounts and gearbox mounts are all the exact same locations except the front ones....because the K75 engine is shorter the loss of the front cylinder means the front down tubes are different.....longer and raked back more to pick up the shorter K75 engine. If you look at a photo of a K75RT and a K100RT/LT you can see how the fairing '[same on both bikes] has a big space under the radiator part due to the shorter engine.
Fair bit of trickery involved.
Also K75 has a steering damper in the stem, not sure how you work that out.
1971 Yamaha 125 YAS-1
