1Back to top Go down   K100 and Side Bike Comanche Empty K100 and Side Bike Comanche Sat Apr 28, 2018 1:24 pm
Here's my new rig:
K100 and Side Bike Comanche K100_c13
K100 and Side Bike Comanche K100_c11
K100 and Side Bike Comanche K100_c12
K100 and Side Bike Comanche K100_c10
I've bought it 3 weeks ago, to its very first owner and manufacturer. He was a professional welder and made a great job, with a very solid subframe which receives the front end coming for another sidecar from Side Bike, the Kyrnos. Nice features with the Gotti rims, the genuine muffler that was converted to a right hand side. But the masterpiece is the sidecar. Very low, with a steering wheel, the "cockpit" is a flip-front which allows to get into and gives access to storage compartments at the front.
No provable mileage, the engine is not running very well, the fuel pump died this morning after I tried to ride it.
It's very easy to handle, maneuvrability is excellent, one hand, or even one finger is enough to ride it.
Maybe it will change its color, or maybe I'll fit a K00RS half fairing on it:
K100 and Side Bike Comanche Comanc14
Or maybe I'll make a swap with my K1.:siffle:
K100 and Side Bike Comanche Comanc13
It seems to be jealous...K100 and Side Bike Comanche Comanc15
2Back to top Go down   K100 and Side Bike Comanche Empty Re: K100 and Side Bike Comanche Sat Apr 28, 2018 1:29 pm
I think I've seen that before!
K100 and Side Bike Comanche Snuffl10
3Back to top Go down   K100 and Side Bike Comanche Empty Re: K100 and Side Bike Comanche Sat Apr 28, 2018 3:10 pm
1 - What language is the license plate?
2 - Custom radiator cowl?
3 - What mirrors are those on the K1?
4Back to top Go down   K100 and Side Bike Comanche Empty Re: K100 and Side Bike Comanche Sat Apr 28, 2018 3:43 pm
duck wrote: 2 - Custom radiator cowl?
From a K100 II, euro market only.
5Back to top Go down   K100 and Side Bike Comanche Empty Re: K100 and Side Bike Comanche Sat Apr 28, 2018 3:57 pm
duck wrote:1 - What language is the license plate?
This is South Venusian plate. But only for commercial vehicules.
Probably k1200rs mirrors or something like that. The right handle is coming from a 2000 BMW
6Back to top Go down   K100 and Side Bike Comanche Empty Re: K100 and Side Bike Comanche Sat Apr 28, 2018 4:12 pm
The mirrors resemble R1100RS the way they're mounted with a through-bolt, especially the RH side.
7Back to top Go down   K100 and Side Bike Comanche Empty Re: K100 and Side Bike Comanche Sat May 18, 2019 2:53 pm
Hi there,
I've not posted here since a long time, but it's time for me to introduce my new sidecar:
it's a '84 K100, fitted with a Side Bike Comanche sidecar.
Not factory made, as the firm only allowed to use Yamaha FJ or GTS. The builder, that wass a very good professional welder, made the sub-frame. Nice job, indeed!
i bought il one year ago and spent a lot of time solving electrical problems. The good welder was a bad electricity technician...
I also killed 3 fuel pumps before I discover that there was a kind of translucid lime in the bottom of the tank that i suspect being due to ethanol blend it today's fuel. The biked started very well, but when the slime was sipped after a few kilometers, it blocked dead the pump.
Some rust also, especially on the custom made right and exhaust, one pipe was cut by the rust. Cut, weld, done.
New calipers were also fitted, the previous owner had plan to fit new Brembo 4 pistons calipers, but they're design to fit a disc 5mm smaller in diameter...and were blocking the front disc.
I also had to make a new paint job on the bike, new tank (the old one revealed a hole when sanding it), new seat and heck (does not respect the model year, but matches much better the sidecar line) with a rare genuine optionnal sport seat from BMW. WHen I bought it it had a police single seat with a big ugly radio box.
At least, now, it runs and drives! Still an issue with the cockpit instruments, but I enjoy it anyway.
K100 and Side Bike Comanche Img_2024
The sidecar is 2 wheel steering. That's why its position is so far from the back wheel. It only turns to the right, whether the front wheels turns to the right or the left, but its angle differs. It's designed to align on one single theoretical pivot point the three lines passing threw the wheels hubs. So there's no effort at all...and even to enough effort to provide on the bar to turn. Driving this sidecar is a bit disappointing, it asks no particular skills! But it's very efficient.
K100 and Side Bike Comanche Img_2027
The sidecar is very, very low.
K100 and Side Bike Comanche Img_2028
The passenger, sat at the rear end, is really into the sidecar. The cover is flipping front to give access to the seat, and to a circular storage compartment all around the seat with 3 openings. It won't allow a big case or bag, but there's a lot of place, indeed. All is made in fiberglass with a steel cage inside.
K100 and Side Bike Comanche Img_2026
I love the wheels also. Gotti rims, 13 inches at the front and on the side, an a big 7x14 inches at the rear. Note the biaised steel mudguard to fit the big tyre!
For rainy conditions, a "deck" is protecting the passenger as it does on a kayak. It clips  around the seat to remain the body dry, only the head and the helmet are outside!
8Back to top Go down   K100 and Side Bike Comanche Empty Re: K100 and Side Bike Comanche Sun May 19, 2019 4:29 am
Very nice, the more I look at it the more I like it. The single side front also looks impressive.
K100 RS
K100RS with 1100 motor Premier sidecar
K100 RT KRAUSER FAIRING
R1200GS
650 Vstrom
9Back to top Go down   K100 and Side Bike Comanche Empty Re: K100 and Side Bike Comanche Sun May 19, 2019 10:04 am
Very nice rig.
I see few of them (not on K100) on the sidecar FB groups I belong:
FRANCE SIDE-CARS CLASSIQUES and les sidecaristes de Facebook.
K100 and Side Bike Comanche Frog15K100 and Side Bike Comanche Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
10Back to top Go down   K100 and Side Bike Comanche Empty Re: K100 and Side Bike Comanche Sun May 19, 2019 10:48 am
It's a funky monkey. Very Happy
Interesting that the exhaust was moved to the other side.  I guess that was done to accommodate that wide rear wheel.
