1 1988 K100 instrument cluster on 1983 K100 Sat Aug 10, 2019 4:08 pm
jande9
I have a 1983 K100 (very early model) and it has an instrument cluster with the horizontal pin stripes on it, so from a later bike.
The neutral light stays on all the time and the gear indicator does not indicate anything, it is blank. It has been like that since I got the bike 5 years ago.
The gear indicator switch was replaced by the previous owner and when I check continuity between the pins at the connector behind the battery, it does change when I change gears so I'm hoping the switch is OK.
Are the clusters from earlier and later K100's fully compatible?
Jan
Jan
