1Back to top Go down   New Member Empty New Member Sat Jul 27, 2019 4:55 am
Phil Moser
Phil Moser
Hi all,
I'm a retired mech + elec eng, run 4 BMs, all from basket cases, make my own parts ( within reason ), make tools when needed for certain jobs. I've probably done > 300 000 kms on 2 wheels in my lifetime and still make mistakes.
1978 R100S, 250 000 kms ; 1983 K100RS, 300 000 kms ; a 1981 R100"ZSGS" ( Zwei Stoßdämpfer Gelände Straße ), a "clone" with a Werner Reinschlüssel 40L tank, R65 gussetted frame using HPN as a guideline, RS engine, lots of other stuff, done 200 000 kms, been to Kilimanjaro ( not me, long ago owner ) ; a 1979 R100S Exclusive Sport with 140 000 kms, gussetted frame similar to above, to copy Reg Pridmore bikes. Handles very differently to 1978 but still not as good as K.
Any inspection by BM diehards generally have them shaking their heads in disgust. I believe in modifying anything internal to a bike ( if it's for the better ) but try to keep the external appearance original. Example : that horrible starter relay under the tank on 90Ss, I'd put in a modern one.
Most things I make, I make a drawing of ( in AutoCAD ) for future reference.
I'm attaching my description of my K gearbox drain modification because this makes that really messy job MUCH easier, but it doesn't make much sense without the pics, so how do I attach pics ?
http://forum.kforum-tech.com/members-upload/uploads/Gearbox_drain_modification.txt
2Back to top Go down   New Member Empty Re: New Member Sat Jul 27, 2019 7:36 am
Go to the Forum functionality section, and try some of the methods within. The graphics of the importing software have change slightly but the methods still work. There are two graphic import icons in the menu above this box. The leftmost one works with this system's image server. The one next to is used to import images you already have stored on an image host.
3Back to top Go down   New Member Empty Re: New Member Sat Jul 27, 2019 10:50 am
I just use a piece of tinfoil to keep the trans gear oil from going down the center stand.
4Back to top Go down   New Member Empty Re: New Member Sat Jul 27, 2019 11:35 am
duck wrote:I just use a piece on tinfoil to keep the trans gear oil from going down the center stand.
From CAD to tinfoil—the classic K rides descending arc of maintenance technology. Giddyup! Smile
5Back to top Go down   New Member Empty Re: New Member Sun Jul 28, 2019 4:46 am
Welcome Phil Smile
New Member Eu-log10  K1100RS/LT - R1200RT - R1100RS - Cagiva SST 350 Ala Verde - K75LT project - K75 Schurgers - K75S - K1100RS - K75RT - K75C
6Back to top Go down   New Member Empty Thanks ! Sun Jul 28, 2019 1:13 pm
Phil Moser
Phil Moser
Arlina wrote:Welcome Phil Smile
Interesting addition to your RS screen ; why ? did somebody break that flimsy deflector ?
So how do I post pics ? Or is "NO PICTURES" absolutely gospel ? A friend on the K100 forum has posted. I'd shrink them down to <25Kb.
7Back to top Go down   New Member Empty Re: New Member Mon Aug 05, 2019 11:58 am
playlikewedream
playlikewedream
New Member 177912
New Member Ir-log10New Member Ir-log10
;BMW; K1 1990 Laguna Blue and Yellow ;BMW;
;BMW; K1100RS 1997 Sedien Blue.;BMW;
Its not about the journey or the destination, it's about the friends you make on the way.
