1Back to top Go down   Wierd !! Empty Wierd !! Fri Jul 26, 2019 8:43 pm
stevenh
stevenh
On the never ending search for the solution to the misfire on my K100 LT. I replaced  the fuel pump and all the tank internals, and fitted a new 4 pin plug to the out of tank cable.
although the misfire continues the fuel pump was operating as it should. But then.........
As the Hall sensors are an issue over time. I replaced them with some aftermarket Halls. My problem is:- the bike is running with the same missfire, but now the fuel pump runs continuosly. Even if I turn off the ignition and take out the key. Fuel pump is still running, WTF I said to myself. The only way to stop the fuel pump was to disconnect the four pin plug.
Could this be a relay problem ?? Any electrical geniuses out there to point me in the right direction. ??
Steve
2Back to top Go down   Wierd !! Empty Re: Wierd !! Fri Jul 26, 2019 9:08 pm
I would be replacing the relay, you don't need a special one just a matching Bosch one.
Before that try removing the relay instead of unplugging the tank connection then replacing it to see if it is the relay.
I doubt that replacing the hall sensors would be directly connected with the pump running on but co-incidental.
As for the miss what have you done to diagnose the miss (I haven't been following the forum closely lately as I have had other BMWs in my life which are problematic and giving me a right royal dose of the shits) my dad always said "son if its got tits or wheels it will give you trouble" Very Happy
3Back to top Go down   Wierd !! Empty Re: Wierd !! Fri Jul 26, 2019 10:20 pm
stevenh wrote: Even if I turn off the ignition and take out the key. Fuel pump is still running, WTF I said to myself. The only way to stop the fuel pump was to disconnect the four pin plug.
Steve
Operating the kill switch wouldn't stop it?
4Back to top Go down   Wierd !! Empty Re: Wierd !! Sat Jul 27, 2019 2:39 am
RicK G wrote: my dad always said "son if its got tits or wheels it will give you trouble" Very Happy
More trouble; tits on wheels Razz Razz Razz
Sounds like a sticky relay, but power off on the bike means power off to the pump too.
Must be more to keep it going.
The only thing that suppose to keep power is the clock.
Bit of a bugger to diagnose from a distance, but indeed try with the kill switch and update us.
Wierd !! Eu-log10  K1100RS/LT - R1200RT - R1100RS - Cagiva SST 350 Ala Verde - K75LT project - K75 Schurgers - K75S - K1100RS - K75RT - K75C
5Back to top Go down   Wierd !! Empty Fuel pump not turning off Sat Jul 27, 2019 5:06 am
Phil Moser
Phil Moser
Had this on mine. With a weak or old battery, the starter relay contacts weld together and the starter runs all the time. The headlamp / load shedding relay is earthed through the starter and so, if you have this problem, switch on the headlights and see if they come on. If they don't, welded contacts are your problem. Open the relay and fix it.
6Back to top Go down   Wierd !! Empty Re: Wierd !! Sat Jul 27, 2019 5:18 am
Phil Moser
Phil Moser
stevenh wrote:On the never ending search for the solution to the misfire on my K100 LT. I replaced  the fuel pump and all the tank internals, and fitted a new 4 pin plug to the out of tank cable.
Steve
Had this, on ALL my BMs ( and VW cars ). It's probably the Bosch metal spark plug caps. What I've had is a crack or dirt in the caps' insulators shorting the spark to earth. On all my engines I've put on non-metal caps. No more problems. On my K, I have Bougicord leads with straight caps and 90° coil connections. I've swapped the 2 dual output coils so that the 2 + 3 coil is in front because then standard Bougicord leads fit, but I can't remember the lengths. The bikes' been like this > 10 years. There's another advantage : the leads then come right up close to the BMW cover plate between the cams and you don't have to reach deep down pull the caps off the plugs.
Where did you get a new 4 pin plug for the tank ? I also need this.
7Back to top Go down   Wierd !! Empty Re: Wierd !! Sat Jul 27, 2019 8:27 am
The more I read the OP's performance complaint, the more I believe the ignition switch is at fault so I'm going to quit reading it. Laughing
8Back to top Go down   Wierd !! Empty Re: Wierd !! Sat Jul 27, 2019 6:46 pm
daveyson
daveyson
Double trouble.
Last edited by daveyson on Sat Jul 27, 2019 6:50 pm; edited 1 time in total (Reason for editing : Added double trouble, prob should say quadruple.)
 ~120,000 km
9Back to top Go down   Wierd !! Empty Re: Wierd !! Sat Jul 27, 2019 8:56 pm
Laitch wrote:The more I read the OP's performance complaint, the more I believe the ignition switch is at fault so I'm going to quit reading it. Laughing
+1 A good clean will often do the trick.
10Back to top Go down   Wierd !! Empty Re: Wierd !! Sun Jul 28, 2019 8:43 pm
stevenh
stevenh
Steve
Nope !
11Back to top Go down   Wierd !! Empty Re: Wierd !! Sun Jul 28, 2019 8:45 pm
stevenh
stevenh
RicK G wrote:I would be replacing the relay, you don't need a special one just a matching Bosch one.
" Tits or Wheels " Yeah that would be something my old dad would say. Wouldn't be far wrong either. Wierd !! 44271
12Back to top Go down   Wierd !! Empty Re: Wierd !! Sun Jul 28, 2019 8:49 pm
stevenh
stevenh
Steve
Funny you should mention the caps and leads.  I have just got back from the local Auto shop with a set of leads just as you describe. No shit, ten minutes ago
13Back to top Go down   Wierd !! Empty Fixed itself Sun Jul 28, 2019 8:55 pm
stevenh
stevenh
Well the fuel pump turning off problem has fixed itself. All good now....... Yeah right
I did pull out the relay and clean up the contacts a couple of weeks ago. Serves me right eh.
I'm going to fit a new one. When I can find one that is. Things happen a little slower than normal here in NZ
14Back to top Go down   Wierd !! Empty Trigger wire test Sun Jul 28, 2019 9:01 pm
stevenh
stevenh
Just had a thought. I am replacing the ign leads and caps. the coils check out ok. I have traced the fault to no 4 cyl.
Anyone know a way to test the trigger/pulse wire to the coils. Does the this wire come direct from  the CDI
And.... do cyls 1-4 and 2-3 fire together in pairs.
15Back to top Go down   Wierd !! Empty Re: Wierd !! Wed Jul 31, 2019 3:27 am
Poupy
Poupy
stevenh wrote: do cyls 1-4 and 2-3 fire together in pairs.
 Yes they do fire together, by pairs.
As concerns the injectors, they open all 4 together, i.e. several times per engine 4 strokes cycle.
Similar topics
»  86 k100 wierd noise
