Number of posts : 7942
tjh1985 wrote:MartinW - I replaced those, but when I pulled them they were black and looked like they hadn’t been changed in a while. One thing I did notice was the plugs I pulled had more of a round bulbous end and the plugs that came up for K100’s at the auto parts store are very straight and narrow. They seem to work, but I don’t have enough experience to know if this is normal or is/will be an issue...feedback?
You may have take off Bosch plugs which have the round end OR you may have take off NGK plug which have a screwed on round end and put in NGK plugs which come without the round end. The narrow straight top you will see is threaded and you need a screw on bobbin with that round shape. If possible get it off the old NGK plugs if you had them. The Bosch one is not removable. You can get those bobbins but maybe someone will have some to send you? Don't run without them because you will cause arcing inside the plug caps and destroy them before long.
1971 Yamaha 125 YAS-1
