1Back to top Go down   HAL Sensor group buy ?  Empty HAL Sensor group buy ? Sat Jun 22, 2019 1:54 am
Hello All
Just been working on a fellow member bike and it turns out to be the HAL sensor is faulty
Does anyone in want to buy into a group buy ?
2Back to top Go down   HAL Sensor group buy ?  Empty Re: HAL Sensor group buy ? Sat Jun 22, 2019 3:30 am
Matt I could be interested get a price.
3Back to top Go down   HAL Sensor group buy ?  Empty Re: HAL Sensor group buy ? Sat Jun 22, 2019 5:07 am
GF Wollongong
GF Wollongong
Ditto
I could be interested ... it's only a matter of time before they go
Let me know a price
Guy
4Back to top Go down   HAL Sensor group buy ?  Empty HAL Sensor group buy Sun Jun 23, 2019 8:14 pm
Hi Matt, I'm interested. Cheers Tom
5Back to top Go down   HAL Sensor group buy ?  Empty Re: HAL Sensor group buy ? Mon Jun 24, 2019 12:05 am
Hello All
so the pricing on the Jaycar  HALL sensor  which are the CY sensors  are
1-9 units $24.95 each AUS
10-24 units $22.35 each AUS
25 + units $19.70 each Aus
Plus postage and handling -
This is not much of a saving so may not be worth a group buy
These are a replacement for the Honeywell units
They need minor modification to the mounting plate
spoke with a few of the K riders that are running these any they have not had any problems
The Quote for the  Honeywell unit is $30.36 US each   6 - 12 weeks lead time
Minimum Order Quantity  or they sit on back order  till production run quantity is acceptable
no modification need
Quote direct from CY is a little more expensive per unit than Jaycar ( they must use a rebate system )
6Back to top Go down   HAL Sensor group buy ?  Empty Re: HAL Sensor group buy ? Mon Jun 24, 2019 12:37 am
Matt what's involved with the modification? Are Honeywell any better than CY?
7Back to top Go down   HAL Sensor group buy ?  Empty Re: HAL Sensor group buy ? Mon Jun 24, 2019 6:18 am
If you need someone to make up numbers to get the discount then I'll take a couple as well.
8Back to top Go down   HAL Sensor group buy ?  Empty Re: HAL Sensor group buy ? Mon Jun 24, 2019 7:27 am
Matt: if that's the H-rated 'hardened' sensors then that's a good price whichever way you look at it. Even if they're the bog-standard type it's still on a par with Europe for once!
